Old 01-19-2013, 01:17 AM
rasibo rasibo is offline
Mein Auto: 2003 BMW 530I
2003 530i gauge problem
I have a 2003 530i when i start the car first in cold weather i allow it to warm up for 5 mins the temp gauge go all the way to the red i then stop the car and turn engine off and back on and everything seems fine after that temp gauge normal from then on.
Can someone tell me what is happening or what needs to be done thank you
Old 01-19-2013, 10:41 PM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
You might have a thermostat that is sticking. Is this the 1st time it's done this?
I'd get this problem looked at right away. The M54 allum engine don't survive
well at all when temps go in the red.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 01-20-2013, 05:54 AM
Fudman's Avatar
Fudman Fudman is offline
When you allow the car to warm up, are you driving it or is it sitting at idle? If driving, then check the tstat. If sitting at idle, more probably the fan clutch. However, neither explains why the problem will cease after warmup. How many miles on the car? If over 100K, you need to replace your entire cooling system. Every part is subject to random failure after 100K.
Old 01-20-2013, 10:11 AM
E36 Phantom's Avatar
I Am The Machine
If the temp gauge is in the red, and you turn it off and right back on without waiting and the gauge is basically back at the middle, you have an electrical issue, not a cooling system issue.
// Chad //
// 1999 Chevy Tahoe //
You're a derbanana
Old 01-20-2013, 08:39 PM
Thanks guys for the respond the car has 169000 km i bought it in october last year the car don't have no history on the car other than it had a rear end colision, other than that the car works fine E36 Phantom i think you are right on this only happen sometimes not all the time.
After the car warm up and i drove off 2-5 mins temp goes to the red i will pull over shut the car off and back on right away and the temp gauge goes to normal and it is fine from then on.
