Old 01-19-2013, 11:58 PM
nhansen907 nhansen907 is offline
Mein Auto: 540i
Trans failsafe prog
This came up on my car while my friend was reversing. It's not the battery because I just put a new one in. Reversing is fine but when I am in drive and accelerate my rpms go up but my car has no power and then the trans failsafe prog comes on and my car seems to have some power as if it was in a high gear. What could this be? My car is a 98' 540i
Old 01-20-2013, 04:47 AM
Fudman's Avatar
Fudman Fudman is offline
Do a search. TPF indicates a tranny failure. You are now in default (2d gear) or limp mode, which is to protect the tranny from further damage. It could be triggered by a bad sensor, bad alternator or a tranny failure. It needs to be reset to see if it returns. It requires GT-1 (dealer), INPA or equivalent to reset. Sometimes its an easy fix and sometimes an expensive one.
Old 01-20-2013, 09:18 AM
Mein Auto: 540i
Thanks, I will look into that. I wanted to see if it could potentially be something i could do myself, with out it bring to expensive. I will have to pull the code off of it and see info can't figure something out before take it into a dealer which charge a **** ton
Old 01-20-2013, 09:29 AM
Fudman's Avatar
Only the GT-1, INPA or equivalent can pull (& reset) a tranny code. Find an indy.
Old 01-20-2013, 12:46 PM
ill540i's Avatar
ill540i ill540i is offline
Mein Auto: Bmw 540i
Had the same problem on my 98 540 the trans oil was burned and had to replace it now it runs fine replaced it 3 months ago
Sent from my MB502 using Bimmer App
Old 01-20-2013, 02:54 PM
Mein Auto: 540i
I will try that too, thanks
Old 01-20-2013, 03:57 PM
Eurojay89's Avatar
Eurojay89 Eurojay89 is offline
Faithful to the fest
Send a message via AIM to Eurojay89
Mein Auto: 2003 530i
Could be the alternator that was my issue
_______________________________________
Old 01-24-2013, 03:18 PM
Mein Auto: 540i
So anyway I took it in for them to do a inspection and they Said I have a forward clutch drum damage. Code p0720 & p0731.
They told me I need a rebuild to my transmission. Would that be worth trying or should I find a replacement one And have it installed?
