Old 01-20-2013, 12:10 AM
Bangsi Bangsi is offline
Mein Auto: 730d
Power Steering is dead
Hey folks,
I got up to go to work today and when i sat in the car to reverse out of my garage, as i tried to steer left, i couldnt do it, my steering wasn't moving, it's very stiff, it would require someone like Chuck Norris or Rambo to move that so as i was being late for work i just left it in my garage, now what you guys think might be the cause of this ?
i was thinking either power steering fluid finished, or pump went kapoot.
any thoughts ?
Old 01-20-2013, 12:47 AM
Dave @nz Dave @nz is offline
Mein Auto: E36 323 Msport, & E30 M3
Hi,
Sounds like your car has run out of power steering fluid for whatever reason or the drive belt for the pump has fallen off.
When you have time pop the hood take a look and then post the results.
Old 01-20-2013, 03:47 AM
Mein Auto: 730d
yeah i was thinking that as well, but i thought someone probably had come around similar situation so thought id ask and see, seen/read/learned alot of things through this forum....alot of useful things not junk, so yeah.
Old 01-20-2013, 02:09 PM
Mein Auto: 730d
Lol you wanted results or updates ? Here it is
I come back home after work, go down pop the hood, check the power steering fluid its fine, i start the the car and the steering its smooth ... GREAT or is it ? I decide to take it for a spin and to check if my steering is fixed perm. But it gets all stiffed up and than normal again, (sorta like holding your left index finger with ur right hand and trying to twist the left finger.)
So anyways friends call and we go grab something to eat, come back to start the car.......but its dead, after 3 tries it starts but than i got al lights on and blinking etc...abs is off, dsc is off, alternator fault, transmission failsafe etc.... So after few unsuccessful attempts of reviving the car or trying to get it to shift gears i get pissed off leave the car there and tomorrow will send it to an indy! Effing stupid bmw electronics and brilliant engineering !
