Old 09-27-2012, 02:32 PM
second 7 second 7 is offline
Send a message via AIM to second 7 Send a message via MSN to second 7 Send a message via Yahoo to second 7
Mein Auto: bmw745li 2004
Coding
Hey I'm in the Richmond Virginia area. Any body want / can link up with me to so some coding for me ?
Sent from my PC36100 using Bimmer App
Old 09-28-2012, 01:10 AM
***CCCP***'s Avatar
***CCCP*** ***CCCP*** is online now
Major
Mein Auto: 745 li
Do u have obd to usb cable? I can do it remotely
Old 10-01-2012, 08:35 AM
First_745Li's Avatar
First_745Li First_745Li is online now
Mein Auto: 2003 745Li
CCCP,
I bought the software and cables..installed the software and thought I was ready to take a shot at coding.... I stopped when this didn't seem right... Although the plug looked like it may fit, what am I missing? The plug doesn't look like it's the right one... or is it?
ID:	343946   Click image for larger version
ID:	343947   Click image for larger version
ID:	343948   Click image for larger version
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-01-2012, 08:46 AM
BimmerBrad7 BimmerBrad7 is offline
Mein Auto: 05 745 LI, 05 Acura RL
I just bought this one. i was told this is correct cable for our cars.
http://www.ebay.com/itm/110953205588...84.m1497.l2649
At CCCP, I might be interested in you helping me remotely. How do you do it would you take control of my computer or?
2005 BMW 745 LI Sapphire Black
Old 10-01-2012, 09:11 AM
Looks like the one I have. Just looked weird when you look at the picture that I took of the port on the car.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-01-2012, 11:48 AM
sirstopher's Avatar
sirstopher sirstopher is offline
bimmerfest Supporting Member
Mein Auto: POS Honda
The photo of the port on your car, thats a "CAP or PLUG", you need to remove it, (Pull it out) then you will see the port.
You may already know this
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 10-01-2012, 12:17 PM
Ahh ok I need to pull that out...I didn't know that..First time even attempting this. Thanks Sir!
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-03-2012, 07:29 PM
Ok, so I finally gave this a whirl... I successfully coded the auto lock feature (at drive off). Yay me! I'll try some other ones over the weekend.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-03-2012, 07:48 PM
sirstopher's Avatar
Did you use NCS expert
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 10-03-2012, 07:49 PM
sirstopher's Avatar
+1 for the successful coding
97 740i e38 - SOLD
02 745i e65
03 Montero Limited
Old 10-03-2012, 08:07 PM
Yes, it was NCS Expert and thanks!
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-08-2012, 05:01 PM
I did the following coding tonight..after the auto lock feature..
CAS
VER_AUT_X_MIN_SENDER_1 - Auto lock after 2min if door not open
KOMFORTSCHLIESSUNG_FB - Comfort closing with remote - windows, sunroof, or convertible
HKL
FUNKTION_TOEHKI - Close trunk with switch on dash
KOMFORT_SCHLIESSEN_HKL - Close truck with fob by holding the lock button (5-8secs)
WIM
STANDRUECKSCHALTUNG - Wipers return to interval when car is stopped
I'm looking for help with the following, help appreciated
1. Welcome lights - when I hit the unlock button on the fob the park light and angel eyes illuminate for a couple if minutes.
2. Engine Oil level - OELSTAND - which module would this be located?
3. Disable Legal Disclaimer - I found a lot of posts regssrding this... but I couldn't find the one place (module) to edit
Also, for the Sunroof module (SHD) - I got an error, missing file... blah blah - I should have taken a screenshot... I'll run it again another day and get the error.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-09-2012, 06:23 PM
For the welcome lights or Follow me home lighting..
HEIMLEUCHTEN_NSW >FOLLOW-ME-HOME LIGHTS - FOG LIGHTS - FRONT
HEIMLEUCHTEN_SL >FOLLOW-ME-HOME LIGHTS - PARKING LIGHTS
HEIMLEUCHTEN_RL >FOLLOW-ME-HOME LIGHTS - TAIL LIGHTS
I dont know what I'm doing wrong, when I try to read the ECU (under the expertmode profile) LMA I get the following error
I believe it was the same error for the sunroof Module (SHD).
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-10-2012, 05:17 AM
Damn!...I cant even get my software to install properly on my comp. My cable came with 3 disks, not sure if I should be using someone else.
Old 10-10-2012, 06:05 AM
Not sure if you got any directions for installing the software. I also attached the coding list I have been referring to.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-11-2012, 06:23 AM
[quote=First_745Li;7123875]For the Follow me home lighting..
After I updated the DATEN files I was able to read the ECU but couldnt find the above entries for Follow Me home lights
SHD
REGENSCHLIESSEN >CLOSE SUNROOF WITH AUTOMATIC RAIN SENSOR (RL) WIPER OPERATION
REGENSCHLIESSENTILT >CLOSE TILTED SUNROOF WITH AUTOMATIC RAIN SENSOR (RL) WIPER OPERATION
When reading the ECU for the SHD module I get the following error even after the updated DATEN files for the E65. These are the last two codes I would like to have, if anyone can help I would really appreciate it. Btw, I posted for help on bmwcoding.com and in no time I got private messages to help, at a cost of $100. I don't know that I want these enable that badly. I'd rather purchase another accessory instead.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-11-2012, 05:20 PM
[quote=First_745Li;7126916]
SHD
Anyone?
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-11-2012, 06:49 PM
***CCCP***'s Avatar
Major
Mein Auto: 745 li
I dont think its possible to code follow me home lights for preface lift im not 100% sure. I never wanted that option but i was reading something like that
Old 10-11-2012, 07:01 PM
oh Bummer
How can we confirm this? What about the Sunroof options?
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-12-2012, 03:38 PM
jiceoo's Avatar
jiceoo jiceoo is offline
Mein Auto: 2007 750 Li
what operating system are you running?
White halos, reverse camera, tinted taillights, 20% tint all around, 35% tint on windshield, roof spoiler, custom painted 22'' GFG's, eibach springs, bmw ipod hook up, calibers painted white to match the lip on the rims
Old 10-12-2012, 04:15 PM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW E65 745i
oh Bummer
Yep, afraid so, if you have a pre-facelift welcome lights are not codeable.
I have replaced my original light module with an LM2 from a facelift LCI E60, I now have welcome lights and activated lights on via key fob.
You can pick an LM2 up for around £90-£150 here in the UK.
Stuart
Old 10-12-2012, 04:16 PM
Windows 7 Professional
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-12-2012, 04:18 PM
CAS
HKL
WIM
Legal disclaimer coding is in the MMI, oil level is also in the MMI, although with a pre-facelift the oil level data is not broadcast on the K-CAN so it will continually say 'updating' there is a way around it but its not simple coding!
Stuart
Old 10-12-2012, 04:19 PM
Stuart
Maybe at later time I'll replace the light module.
Is it the same for the Sunroof options I want to code?
Thank you for the confirmation.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 10-12-2012, 04:23 PM
No worries, I'm afraid I don't have a sunroof so I don't know. Good luck with the rest of your coding though!
Stuart
