E90/E91/E92/E93 (2006 - 2013)
Old 01-20-2013, 09:02 AM
loso81 loso81 is offline
Mein Auto: 335i
Hpfp fail, fml!!!
I few days ago i posted a thread about my car lagging and what not. I took the car to the bmw dealership for a diagnostic test on FRIDAY(two days ago) to see what the problem was with the car. The results came back with negative findings. The serviceman said everything checked out and nothing came up error wise. 30 mins ago while driving my HPFP light came on in my dash, FML!!!! IM so livid right now. Good thing i still have warranty but this issue should have been found on friday IMO. ONly problem is, I live in new jersey and I'm in Connecticut visiting my gf's family. Tomorrow is a holiday and i don't know if any BMW dealerships are open tomorrow.
Old 01-20-2013, 09:11 AM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi Sedan
I realize you are frustrated but consider two things to calm yourself a bit, before confronting the dealer:
  1. Not all intermittent failures or drivability problems store fault codes. There may not have been anything there for them to find on Friday, and if they can't get the car to reproduce the problem you describe and report a fault, they cannot do anything under warranty. Frustrating sometimes, but that's just the way it works.
  2. There is no "HPFP light." The symbol in the cluster is "reduced engine power," better known as "limp mode." It can be caused by a wide variety of problems of which the HPFP is only one. The good news is, a limp mode event will store a fault code so the dealer should be able to identify the problem this time around.
Good luck.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
Old 01-20-2013, 10:47 AM
Mein Auto: 335i
after I stopped driving the car, I turned the car back on and the light was no longer in the dash, since its not in the dash anymore I wonder will the dealership still be able to detect a problem or not?
Old 01-20-2013, 10:59 AM
Washburn's Avatar
Washburn Washburn is offline
Mein Auto: AW 330Ci ZHP
The codes should still be stored in the system/OBD memory, even if the light is not 'on' on the dash anymore. So yes, they should still be able to detect them.
2005 Alpine White 330Ci with ZHP
Old 01-20-2013, 11:29 AM
tturedraider's Avatar
Freedom isn't free!!
Dealerships will be open, no need to worry about that.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- Geo. Orwell
Keep Right, Except to Pass
Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool."
2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it!
2004 330i ZHP Imola/NB - missed
2000 328i TiAg - gone but not forgotten
BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School!
Old 01-20-2013, 11:31 AM
Bill-SD's Avatar
Bill-SD Bill-SD is offline
Mein Auto: 2007 335i Coupe
You'll be fine. Now the dealer will know what the problem is. More than likely it's not the HPFP.
Monaco Blue/Saddle 335i Coupe - Auto|Sport|Premium|Nav|CA|Sirius|Heated Seats|PDC
Old 01-20-2013, 11:42 AM
Mein Auto: 335i
well if its not the hpfp that's causing the jerking/lack of acceleration what could it be after doing research I've read a lot off ppl have problems with the fuel pump, only other thing I can think of is the injectors that may be the problem
Old 01-20-2013, 11:47 AM
Washburn's Avatar
I guess we/you'll know when you take it to get the codes scanned...
Bill-SD's Avatar
You, more than likely, have a new fuel pump. I'm not sure I'm seen anyone talk about them failing with the new pump. There are lots of things that could though you into limp more. That's just your cars way of protecting itself from damaging something else. When you go into limp mode, you can turn your car off/on to get out of limp mode. But you definately want to get it checked out. If you have a code reader, you can get the code yourself and find out what the problem is.
Old 01-20-2013, 12:14 PM
fun2drive's Avatar
BMWCCA 149159
Mein Auto: 335 vert//M3/4/ 13Outback
Remember the HPFP is warranted for 120K miles and 10 years by BMW.
Could be LPFP, injectors or maybe and I say maybe HPFP which seeing failures anymore is getting to be uncommon...
Old 01-20-2013, 02:05 PM
ctuna ctuna is offline
Mein Auto: 325xi wagon
How many miles did you mention it?
Have you checked the intake valves to see if there is carbon build up ?
Maybe it needs a walnut cleaning.
Old 01-20-2013, 03:50 PM
DSXMachina's Avatar
Automaticallyparsinglinks
Our cars come with walnuts? And how do you clean them?
Old 01-20-2013, 03:53 PM
captainaudio's Avatar
Worlds Foremost Authority
Mein Auto: 335i E93 - 750Lix
Dirty walnuts can be a big problem.
If you encounter any they should be cleaned immediately and baked into cookies.
CA
Drivers Club at Lime Rock
The Glen Club
BMWCCA
Cayman Club Nor'Easters
Sports Car Club of America
American Mural Project
Old 01-20-2013, 04:37 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
CA
yes, that is the only way to be sure.
it could also be a boost leak.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 01-20-2013, 05:47 PM
Mein Auto: 335i
I'm currently not at home I'm 130 miles from home, should I take the risk of driving my car home or just take it to a local bmw dealership in the area where I am currently located?
Old 01-20-2013, 08:06 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
That's not a HPFP light....don't remember any HPFP light.
It is an engine issue. Ask your dealer for a readout of all codes found - interested.
Old 01-20-2013, 08:21 PM
Mein Auto: 335i
-CAL yea I realized that later I'm hoping to get it checked out tomorrow if any BMW dealerships are open tomorrow is a Holiday.
Old 01-20-2013, 09:45 PM
unrealii unrealii is online now
Mein Auto: 2009 335 6MT 'vert
My car gave me that light when one of my hoses popped off. The shop which worked on my car earlier that day forgot to tighten the clamp on the hose exiting the FMIC. I reconnected it and it worked fine afterwards. Glance under to see if anything looks out if place.
Sent from my HTC VLE_U using Bimmer App
2009 335i 6MT M-Sport AW/CR Convertible & Border Collie
Old 01-21-2013, 08:41 AM
E92-Lighting's Avatar
PM me for combo pricing
Send a message via AIM to E92-Lighting Send a message via MSN to E92-Lighting Send a message via Yahoo to E92-Lighting Send a message via Skype™ to E92-Lighting
Mein Auto: 335
sorry to hear!
Old 01-21-2013, 10:35 AM
former230 former230 is offline
Driving around somewhere
Mein Auto: nothing at the moment
Sorry if I missed it somewhere, but what year is your 335i?
Hope it gets straightened out for you in short order.
Old 01-21-2013, 01:05 PM
Mein Auto: 335i
Alright, so i took the car to the bmw dealership this morning, i was there from 820am-1215, from what was told me to so far they say that it seems like an issue with one of the turbos. I have a loaner and they say the car is most likely going to be there overnight. Thats the most updated info i have at the moment, i don't care how long it takes as long as they fix the damn thing. So far my loaner is a 2012 335i sedan....i can definitely feel a difference in the acceleration with this car vs mine.
