Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11)
Old 01-20-2013, 10:40 AM
car-man car-man is offline
Mein Auto: 2012 528xi
Low coolant warning, BMW dealers all closed, what to do?
My coolant warning came on and the reserve is empty. Can I add distilled water or some other coolant in the meantime? BMW dealer is about 30 miles away so I'll need to do something to the car to the dealer anyway...
2012 528xi
Old 01-20-2013, 10:47 AM
The X Men The X Men is offline
Mein Auto: 2012 535xi 2012 X3 35i
I would not add water in there, it might freeze up. You should try to drive to the dealer. If your car throws a high coolant temp warning on the way there, you should shut off the car immediately and get it tow there. Good Luck.
Old 01-20-2013, 10:50 AM
Leslierc's Avatar
Leslierc Leslierc is offline
Sejanus
Mein Auto: `11 MSport 750ix/`08 135i
Check your manual for the correct response. You should be able to add coolant. Usually, coolant needs to be diluted with regular water.
2011 Panamera 4S...GT Silver / Espresso
2012 Mini CooperS convertible
2008 135i Convertible - Sparkling Graphite Metallic
Prior BMWs: `05 645CiC; `07 650i; `08 M6 convertible; `11 750ix MSport
2004 GX470
Old 01-20-2013, 11:34 AM
numbersguy numbersguy is offline
Mein Auto: 2013 535i
It this is from a gradual loss of coolant over many months and there is no temperature warning than you should be able to drive it for a while, certainly until you can take it to the dealer. If there has been a rapid loss of coolant then there would be a temperature warning and of course you must shut it down immediately.
Most coolants are meant to be mixed 50/50 with distilled water. Adding a pint or so of distilled water wouldn't hurt if you add an equal amount of coolant later as soon as possible.
Old 01-20-2013, 12:17 PM
alextremo alextremo is online now
Mein Auto: F10 550i
If you are near Canton I have some BMW premixed coolant you can use. If not, I'd just go to the dealer tomorrow when they open and have them top it off.
Old 01-20-2013, 12:23 PM
H F H F is online now
Mein Auto: 2005 545i
OReileys has blue bmw coolant,,,,
Old 01-20-2013, 12:39 PM
SuperTerp SuperTerp is online now
Mein Auto: 335x RIP, 760, 550x, M3!
Can't you just add that premixed coolant and throw it in?
OP if you've got someone that can give you a lift leave your car in the dealer lot overnight and call them up in the morning.
Old 01-20-2013, 12:50 PM
OrthoPT OrthoPT is online now
Mein Auto: 2011 535i xdrive
You can always use bmw assist to have it towed
Sent from my SCH-I535 using Bimmer App
