E34 (1989 - 1995)
Old 03-07-2011, 07:44 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is online now
Humble E34 lover
Mein Auto: 1992 525i
Mechanical things you need to know about your E34 - UPDATED 3/22/11
Stomp Test Procedure moved to top of list 3/22/11
Hello fellow Festers. This is a thread designed to be comprehensive in nature and assist current and new E34 owners with some of the common problem areas and failures of the E34. Please feel free to add to the list as I'm sure that I will not remember everything. I will update the original list accordingly. Of note, I will only plan to add things to the original post that are known problem/failure areas, preventative measures one can take and the recommended fixes that are universally accepted and recommended. Some have suggestions that are "unconventional" that they have had success with. There is a thread coming for those suggestions. This list is compiled from my years of owning BMWs as well as the experience of others who have basked in the glory of the mighty E34. There are some caveats with this list due to the varying models of the E34, but it should be a good list to cover most situations/models.
First things first …......... Obtain a copy of the Bentley manual. It is by far the most comprehensive repair manual for the E34. Here is a list of problems/failures that are common on the E34 and preventative measures.
I decided to move the stomp test procedure to the top of the list. This is absolutely the first procedure that should be done to diagnose a problem (unless of course your radiator is puking coolant due to a busted hose or something obvious like that) Our BMW has a computer (OBD I - on board diagnostics I) that will store fault codes if it detects a problem with many of the components of the car. Per the Bentley manual, this works for 1992-1995 models only. This is one of the very first things that should be done if you experience driveability problems or if your check engine light (CEL) comes on. Many have asked how to perform the stomp test. I decided to create a thread dedicated to this procedure. Follow this link for the step by step procedure with the associated fault codes:
http://www.bimmerfest.com/forums/sho...65#post5936965
Cooling system
Do not let your engine overheat !!! This cannot be stressed enough. If it gets to the red zone, it is in danger of major damage including a blown head gasket and/or a cracked head. This is a very difficult DIY and very expensive if done by a mechanic. The E34's cooling systems is its Achilles heel.
- One may want to consider a complete cooling system overhaul every 100K miles or so. The best case scenario is replacement of the radiator, belts, hoses, pulleys, water pump, thermostat, thermostat housing, fan clutch, fan, radiator cap and bleed screw. Of note here, there is a special fan holding tool that is invaluable to removing the fan assembly. A 32 mm wrench is required for the large nut holding the fan clutch to the water pump shaft. This is a reverse threaded nut, so the wrench has to be turned clockwise to loosen the nut. The holding tool and wrench can be obtained online for about $30-$35. It is money well spent. Believe me, I know because I ruined a water pump pulley trying to use the inappropriate tools. A regular coolant system flush can help stave off some of the problems. A coolant system overhaul is not a difficult DIY on the E34. Please see post # 10 for two very good videos on the BMW coolant system (thanks Bluebee ) While the E34 is not listed, virtually every single thing in the videos apply. The only real difference is the location of the bleed screws. In fact, the radiator in the second video appears to actually be an E34 radiator.
- Some of the parts of the cooling system from the factory are made of plastic that, over time, will fail. The upper radiator neck is a common breakage point. The plastic bleed screw can fail/break easily. Be careful not to over tighten the bleed screw as it should not take a lot of torque to get it to seal. Brass replacement bleed screws are available that are very nice looking and will not break.
- If replacing the fan, it is universally recommended that you only use the oem fan as the aftermarket ones are of inadequate quality and are prone to breaking apart. The fan clutch is an item that can fail. When new (and the engine off and cold), the fan clutch turns like the internals of the clutch are like molasses. If it turns with virtually no resistance or it will hardly turn at all, then it is time to replace it.
- The factory water pump comes with a plastic impeller that over time will disintegrate and cause an overheat situation. There are water pumps available with a metal impeller as well as ones available with a composite impeller. It is a universally accepted recommendation that the plastic impeller water pump be replaced with the metal impeller water pump. There is also a high flow water pump that is pricey, but is reported to flow much more coolant. It is commonly used in racing situations. The thermostat housing is made of plastic and there are aftermarket aluminum housings available. The design of the thermostat housing is such that a sealant is not required if all mating surfaces are smooth, straight and properly cleaned. However, premium high temp thermostat gasket sealant can safely be used as an extra measure (thanks LD), just be sure to not use too much as it may get into the coolant system. The t-stat for the E34 comes in three different temperature ratings, 80, 88 and 92 degree Celsius. My recommendation would be to replace with the one that came in the car from the factory. Some opine that lower temp t-stats allow the engine to run cooler. Others say it only allows the engine to cool sooner because it opens at lower temps. Do your research as the jury is out on this one.
- BMW recommends its brand of coolant only, but it is pricey. Some suggest that you can safely use less expensive coolant that is green and has a sweet odor. This can aid in visual discoveries of leakage as well as being more apt to smell coolant if it is leaking. Many have had good experiences with the lesser expensive brands. There is a very detailed thread on this here : http://www.bimmerfest.com/forums/sho...d.php?t=523954
- Many feel that bleeding the coolant system is as difficult as brain surgery, but if done according to the Bentley manual, it is not difficult and can be done in one to two bleeds. Of note, the 540 reportedly has a self-bleeding system. One key is to make sure your heater is on full hot and the fan is on maximum. You can also elevate the front end 6 inches or so to help the air move up and out of the system. A sign of a coolant system that has not been completely bled is an overheat situation in combination with no/little heat from the heater.
- If allowed to overheat, the head gasket can fail and/or the head can crack. If this happens, it is bad. Signs include an engine that continues to overheat and loose coolant despite topping off. Of course, if one just loses coolant, the one should examine the entire system for a leak. Other signs include milky looking oil, oil in the radiator, bubbles in the expansion tank when the engine is running and large amounts of steam coming from the exhaust pipe. A compression test and/or bleed down test are two of the more definitive tests for a blown head gasket and/or cracked head. The oil and coolant can also be sent off to be analyzed.
Fuel system
- The fuel system can present instant or insidious problems. Frequently a car will not crank well, be low on power, have severe hesitation or just suddenly quit. The best way to address the fuel system is in an orderly fashion. First check the simple things, i.e., make sure you have gas in the tank (sorry, but it happens). Next, check the fuel pump fuse. If bad, replace. If not proceed. If you have a can of starting fluid, squirt it in the air box for about 2 seconds. A word of caution here, the MAF has a wire that heats up and can potentially cause a fire with the starting fluid, but I think that is rare as hen's teeth. Anyway, if the car cranks and runs for a second or two, you have essentially narrowed the problem to a fuel delivery problem. If this is the case, then you need to proceed with a little more detailed diagnostic procedure.
- If the fuel filter has not been replaced in a long while, then you should replace it. BMW recommends that it be replaced every 30K miles. Some feel that they can be cleaned, but again, I am sticking with recommendations that are either recommended by BMW or universally agreed upon. Now you need to check to ensure that there is power to the fuel pump. This is accomplished with a multimeter and by jumping two terminals in the fuel pump relay socket (#30 and 87). Here are a few pictures of the jumper I made according to Bentley manual instructions.
- I will not go in to great details on the socket jumping procedure here because the information is here in this link kindly provided by Roberto (it's from the Bentley manual that is a must for E34 DIY'ers).
http://www.bimmerfest.com/forums/att...2&d=1299708539
- If the fuel pump purrs when the sockets are jumped, then the fuel pump relay is bad. It is a very good idea to have a spare fuel pump relay with you at all times. If the car suddenly stops on you, you can simply replace the relay. If that is the problem, the voila, it is now fixed. If the fuel pump does not purr with the relay sockets jumped, then the pump is likely bad. It is possible that it is the wiring from the FP relay to the pump, but that is unlikely. Sometimes the pump is just weak and in early failure. This can be tested by checking the fuel pressure at the fuel rail. I am not very familiar with that process or the pressures that should be present. Someone please chime in here. Finally, the injectors may not be firing or may be clogged. They can be tested with a multimeter and there is a flushing and back-flushng procedure as in this video:
Thanks Roberto . It is very uncommon for the problem to be fuel injectors if there is a sudden no-start situation or if the car suddenly dies while driving it. The fuel pressure regulator can also be a problem, but it is not very common. Someone may be able to chime in with more information and I will add it here.
BMW factory radio code reset procedure. Here is a direct quote from the BMW anti-theft radio owner's manual:
"To enter your security code, which can be found on the two cards supplied to you by BMW, turn the radio on and use the appropriately numbered radio push-button selectors. If the correct code is not entered in three successive tries, the radio will not accept another entry until it has been left on for one hour.
Important: If you make a mistake in entering your code, complete the entire sequence before entering the correct code. For example, if you r code is 12345, and you mistakenly enter 125, finish the five-digit sequence (45) to complete that entry. The radio will not operate, and the wok "CODE" will again appear on the display. Enter the correct code this time.
Exception: IF you hear a beep when entering your code, stop immediately! Begin entering the code again, starting with the first digit."
More to come later
Steve
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-07-2011, 09:30 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Good informative advice. On the cooling system over hauls. A few things that i experienced. The radiator does not have to be removed If its not being replaced. The plastic thermostat covers should be changed to metal because they warp and leak over time. I used use a premium high temp thermostat gasket sealant on older blocks With a 88 degree thermostat .The water pumps should have Stainless steel impellers. I used a aluminum impeller water pump.The brass Air bleed is a brilliant addition to the Radiator, Bleed of air 4x. It can take a week for all the air to be bled out.Once the air is out the coolant temps will stabilize I agree it would be best to use OE BMW fluids 11 qts is 2.3/4 gallons of fluid. 3/4 of a gallon is always in the car unless your vacuming it out .Run the water hose in the expanshion tank 30 min open the rad drain.Run cabin climate control to clear any air in lines The long fan cluch wrench and fan holder make removal a breeze,then instanty resold. The serpentine belt should be replaced at this time if its fraying or very cracked on the rib side. draw a rough picture of how its woven around the pullys . LD
Old 03-08-2011, 05:15 AM
BMR_LVR's Avatar
Humble E34 lover
Originally Posted by luckydog View Post
Good informative advice. On the cooling system over hauls. A few things that i experienced. The radiator does not have to be removed. The plastic thermostat covers should be changed to metal and use a premium high temp thermostat gasket sealant on older blocks With a 88 degree thermostat .The water pumps should have Stainless steel impellers i used a aluminum impeller water pump.The a brass Air bleed is a brilliant addition to the Radiator. It would be best to use OE BMW fluids if you can. LD
Thanks LD. In the thread above I indicated that the radiator replacement in the overhaul recommendation would be in the "ideal" or "best case scenario" as they are known to have breakage problems (upper radiator hose neck, bleed screw receiver) and leak problems around the expansion tank. If they do fail, it is frequently sudden and there is massive loss of coolant increasing the risk for an unintended overheat and being stranded on the road. Plus, E34 radiators are not readily available at the local parts store and usually have to be ordered and shipped in.
I did address the aluminum t-stat covers and metal WP impellers in the original post. I will add the issue of the high temp gasket sealant on older blocks (any specifically as sealant is not required if all mating surfaces are in good order and the area is cleaned well?) I also did mention the BMW recommendation for oe coolant but listed the non-oe fluids as an option if the person is so inclined.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-08-2011, 08:57 AM
Elijahbmw Elijahbmw is offline
Mein Auto: 1990 525i
My battery keeps dying...I was told there was a computer chip draining it, would you happen to know where I could by one or at least give me a price quote by any chance?
By the way I have a 1990 525i
Old 03-08-2011, 09:14 AM
BMR_LVR's Avatar
Humble E34 lover
Hello Elijah. Unfortunately, electronics is not my strong suit. There is a method for detemining where an electrical drain is, but again, I'm not very well versed in such electrical diagnosis.
I would suggest that you post a new thread with your question. I imagine that there are those here that can provide you with some quality assitance.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-08-2011, 09:37 AM
luckydog's Avatar
BMW Euro replacement battry min 650 cc amps Car Quest Auto parts about $120. A must do.
Old 03-08-2011, 08:43 PM
gomfrddy gomfrddy is offline
Mein Auto: 90 525i
make sure yiu relace yor timing belt every 60k miles!
Old 03-08-2011, 08:57 PM
BMR_LVR's Avatar
Humble E34 lover
Thank you Gomfrddy. I tend to forget about the M20's
I'll add to the original post when I do the engine portion.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-10-2011, 07:29 PM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
stay vigilant on the updates Steve! its coming along great!
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
Old 03-11-2011, 12:21 AM
These two videos cover all you need to know mechanically about the weak points in the E34 cooling system:
BMW Cooling System Failure Points, Part 1 (e36, e46, e34, e39):
BMW Cooling System Failure Points, Part 2 (e36, e46, e34, e39):
Old 03-11-2011, 08:52 AM
Monsignor's Avatar
Congrats on the sticky Steve
Nothing a little PM can't do, am-i-right?
Sent from Joe's iPhone using BimmerApp
2006 325i/6 48k mi
Garden State Euros
Old 03-11-2011, 09:08 AM
Banned
Mein Auto: car
Stick it to 'em, O gentle spook ! Gosh the heat's really on now..lol
Old 03-11-2011, 10:00 AM
BMR_LVR's Avatar
Humble E34 lover
Yes sir! Thank you. I didn't want to be pretentious and request it myself.
Yeah Roberto. Still waiting on the "Unconventional Wisdom for the E34" thread.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-11-2011, 10:04 AM
Banned
Mein Auto: car
Oh no. I'll be writing about what to do if you've just bought an E34/ are about to buy one.
Old 03-11-2011, 10:39 AM
BMR_LVR's Avatar
Humble E34 lover
I thought you were going to cover some of the unconventional things that you recommend like the fuel filter wash out, diesel fuel additive to the crankcase and fuel tank, etc., etc.
No?
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-11-2011, 10:55 AM
Banned
Mein Auto: car
No?
Steve
Yes sir that will be included where appropriate. I was referring to the thread's topic in my earlier reply. Most of what i intend to describe will be decidedly conventional which i would pretty much now do with any used car that i buy, regardless of make and manufacturer. Of course a few things could be entirely specific to the E34 - i don't have that much experience with any other vehicle to say otherwise.
The post will serve as a useful reminder, will at least alert people to the demands of owning an older vehicle, and will be checklisted for easy reference. At least i hope it turns out that way. And with such an extensive buildup, I'm sure it will be a disappointment.
Old 03-21-2011, 06:54 PM
TWard's Avatar
TWard TWard is offline
Mein Auto: 91 e34 525i
Hmmm i request a 5 speed swap
Old 03-21-2011, 07:16 PM
BMR_LVR's Avatar
Humble E34 lover
You do the write up (with pic of course) and I'll add it
Glad to see you back again. Maybe I can swing by Lexington some time to check your project out.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 04-12-2011, 05:25 AM
gussee gussee is offline
Mein Auto: 1989 525i bmw
hi i have a 1989 525i bmw the power lock,the windows,the sunroof,the seats and the radio stop working all together i checked the fuses but there fine can anyone help me out please
Old 04-12-2011, 05:28 AM
BMR_LVR's Avatar
Humble E34 lover
Hey friend. Welcome to the Fest. I'm sure that there are those here who can help you. I suggest you start a new thread as people generally only look at the main page on this thread since that is the way it is designed. So, start a new thread with your questions and I'm sure you'll get a response.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 04-18-2011, 04:51 PM
Christo5er Christo5er is offline
Send a message via Yahoo to Christo5er
Mein Auto: 1990 BMW 535i
... Excellent list, thanks for posting it !
Old 04-18-2011, 05:21 PM
BMR_LVR's Avatar
Humble E34 lover
Thanks. Hopefully I'll get off of my butt and work on the list some more.
Steve
PS: Welcome to the Fest!
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 04-23-2011, 10:05 PM
luckydog's Avatar
2 speed temp controlled Aux fan switch 80 -88 degrees
I'm just about to spring for this cooling system part $40 shipped. Its the aux fan switch that is thermostatically controlled. The stock switch for E34 M50 engine calls for the Aux fan to come on at a hot 91 -99 degrees Centigrade. The aftermarket aux fan switch will come on at 80-low speed 88 high speed Degrees Centigrade or about 10 degrees lower. I think this will help keep the engine cooler sooner this summer .Ill keep you posted of the results.http://www.bavauto.com/shop.asp Part # : 61 31 8 361 787 under the radiator section at Bavauto.
ID:	275907   Click image for larger version
ID:	278616   Click image for larger version
Old 04-23-2011, 11:51 PM
Banned
Mein Auto: car
It should be possible to fit resistors in series with the coolant temperature sensor's switch to achieve the same effect. Resistors cost a few pennies or dimes. Of course, some research will have to be done to test resistances and currents under different temperature conditions. Buying it straight off will be much easier.
Old 04-24-2011, 06:10 AM
BMR_LVR's Avatar
Humble E34 lover
Thanks. Let us know how it goes. Keep in mind that, with the lower temp switch, the aux fan will be coming on a lot more. Not that that's a bad thing, but it will create more wear and cause an earlier fail of the aux fan than if left stock. I had an aux fan go out on my previous E34 (may she RIP ) and it was going to be very expensive to have it replaced by my mechanic. Mind you, this was prior to my DIY days with Bimmers, but still, there is a lot involved with changing one out. And the fan itself is pretty pricey. As long as your coolant system is healthy, then the stock set up should be fine.
Would you consider wiring in a manual switch to the stock set up where you can manually activate the aux fan? Here's another thing to think about. If the hot temperatures in the summer are concerning you, then you would likely have the A/C on during the hot days, correct? The aux fan is automatically turned on when the A/C is engaged.
Anyway, let us know how it goes and if you notice any difference in your car's temp.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
