E46 (1999 - 2006)
Old 01-20-2013, 02:28 PM
haris23 haris23 is offline
Mein Auto: E46 325i
E46 Sub/Amp Install
Alright, so I have installed subs and amps for quite a long time. But I have never dealt with a LOC (line out converter). I have a 2002 325i, non HK system. I have a line out converter, (Raptor LOCA25 to be exact). The damn thing did not come with any instruction manual at all. Thus far, I tapped into my left 6X9, and wired the LOC. It came with 5 wires to use, a brown which I assume in a ground, a white and white with stripe, and a black and black with stripe. I am assuming the ones with stripes are the negatives. My amp turns on no problem, RCAs are connected, grounds are good. But I am not getting any sound. What am I doing wrong? I faded the sound to the rear speakers as well and no subs.
Old 01-20-2013, 02:44 PM
coopers coopers is offline
Mein Auto: 2001 Z3 2.5i
Not sure what you mean by tapping the 6x9, but a LOC is supposed to sit between your head unit and your amp.
Most amps cannot handle head unit output (which is variable). The LOC basically evens it out (makes it constant) for amp input.
I am sure that there are folks out there who can explain it better than I.
Old 01-20-2013, 03:09 PM
Mein Auto: E46 325i
Well from what I read from some guides, it had said to take the speaker wire from the 6x9 and splice it to use for the LOC. Maybe I am doing it wrong.
Old 01-20-2013, 04:08 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Your best result will be from tapping the head unit signal source, not the speaker-level source from the factory sub. That is frequency limited, while the signal source is full frequency giving you much better tuning capabilities.
Look at the spreadsheet/wiring diagram in my thread here: http://www.bimmerfest.com/forums/sho...d.php?t=149113 You are interested in the wires/pins marked "Head unit..." Tap into the rear, feed those to your LOC, then connect to your new amplifier.
I'm color blind, so I prefer to look at positional data vs wire and stripe colors, so those are not included in my wiring chart. The references at the start of my article indicate colors. You are only interested in the Grey and Black connector info for your project.
Jeff R.
Old 01-20-2013, 05:49 PM
Mein Auto: E46 325i
Thank you for your help. But doesn't the non HK not have an factory amp?
Old 01-20-2013, 06:56 PM
jvr826's Avatar
Is it Trackday yet?
You didn't read much of my article. To make my cannibal connector...
I purchased a used standard amplifier for a 1999 E46 Sedan from a guy on eBay
All US bound E46's have a separate amp with the same connectors. It is behind the trim panel on the left (driver) side of the trunk.
A visit to the WIKI will also give you a great explanation of how the system is put together and what your upgrade options are.
Jeff R.
Old 01-21-2013, 06:43 AM
Nygel's Avatar
Nygel Nygel is offline
Mein Auto: BMW 750Li
First lookup your vehicle colors for the speaker wires.
Second you need a device like a JBL Cleen Sweep or a Audio Control LCi7. Device like these will allow you to tap into the speaker leads and keep the connect to there orgiinal speaker if you choose, plus you will get a balance left and right.
The problem with LOC's tapped into the orginal speakers are it turns into a type of RF mic when you turn the headunit off and power is still applied to the amplifier (a loud constant humming with no control).
hope this helps
