E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Tranny fluid leak at bottom of the pan
Just bought a 2004 325CI convertible. 100K miles
As a long time BMW owner I'm very pleased with this car, but when I changed the engine oil I noticed the bottom of the tranny pan was wet and blowing back on the exhaust. I'm fairly confident it is tranny fluid. When I purchased the car I reached underneath the car to check for any leaks after a test drive and there were no noticeable leaks. Unbelievably it is not hitting the driveway or garage floor. The car was sitting on the BMW dealers lot for around 45-50 days. Does anyone have any thoughts as to where to start looking for the source of the leak. |
Make sure it is tranny fluid. Do you have an automatic? If so, I would not drive it long without fixing that- once you confirm. Your description is typically an engine oil leak spreading back across tranny pan.
Yes, it is an automatic transmission. I will put it back on the jack stands and verify the fluid.
Oil Filter Housing Gasket (OFHG) or Oil Pan Gasket are two typical suspects.
Thanks, I will pull the bottom cover off and check the (OFHG).
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
