E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
E46 323i 2000 won't Start, Have video, Please help!
I have a BMW that randomly won't start. Seems to be when it gets really cold.
Here is a video of the same symptoms as it has happened again. * I have a new battery 49DL from AutoZone ** Changed Fuel Pump, Fuel Filter, Fuel Pump Relay, checked all fuses. I'm clueless. *It is not 36 degrees outside, it has done this before in the last month twice. 32 degrees and another in around 37 degrees. Last edited by idonic7; 01-20-2013 at 06:09 PM. |
Have you checked all of the grounds? I had a weird starting issue and it turned out to be the ground connection to my battery.
Check the obvious stuff first. Google "E46 ground strap" which is a braided cable that goes between the engine mount and the frame rail.
Jeff R. Golden Gate Chapter BMW CCA - Autocross - Come Join Us! ![]() "You drive like old people $#@%... slow and sloppy!" - George Carlin |
Would that ground strap make that one light flicker like that? Is that normal with a bad ground?
These cars are very sensitive to electrical anomalies. Why not just check the easy stuff first?
I was in a friend's M3 one evening, started and ran fine and had no symptoms... ever. We made one quick stop and when we went to leave, it was dead as dirt. The battery just crapped out at that moment with no warning. You said you have a new battery, but have you checked it's charge?
I'm with JVR, check connections to the battery and make sure everything is tight. Assuming it is, I'd unplug the seat and light when it happens and see if that lets it start. Question: when it does happen, how do you get it working again?
Battery sits at 12.4
The car magically starts again the next day or several hours later. Runs like a champ! |
I'm going to check the ground strap in the front. If you have any other ground things I should check please advise. Remember if it helps at all.. the grass is white here.. frosted over.. so its cold. That is why it's not starting now.
I took the strap off today although it looked tight and clean. used a wire brush on it tightened it back. Still nothing. You are suggest that I disconnect the seat and the light and try? Will do tomorrow. Its dark quick and very cold out there.
Please!! Help! Have no idea where to move forward to! 3 days
( she won't start !!
I'm no expert and probably the last person you should take advice from but have you tried jumping it? While the battery obviously has power maybe with it being that cold outside (it's going to be 82 here today
Of course my dad would tell you the problem is you bought a battery at AutoZone. |
It won't hurt trying
I'll try to jump it tomorrow ![]() I just purchased a new set of spark plugs, has 160k miles on it. IDK what the problem is but I'm in pretty deep so might as well keep going. Purchased NGK Platinum 4 prong |
Hi can anyone help? Ihave a e46 2000 that wont start have new pump relay check all fuse stil not start?
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
