Old 02-21-2013, 01:31 PM
xjoe97x xjoe97x is offline
Mein Auto: 2008 328xi
coolant sign keeps popping up..water pump?
got a 2008 328xi e92 coolant warning came up a couple days ago so i filled it up not even 3 days later it says its low again so i go check it and its bone dry...dont really see any leaks but from what i hear it can be the water pump? any suggestions and btw car is out of warranty
Old 02-23-2013, 10:52 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Is the car overheating? Coolant loss can be internal engine leaking through the headgasket and burning out through the exhaust ($$$$), heater core, or a leaking waterpump (typically the mechanical ones around 100K miles). If underengine cover is on you may not see leaks that are present. Could also be as simple as a heater hose cracking. How many miles?
Old 02-23-2013, 11:44 PM
CALLAWAY845 CALLAWAY845 is offline
Mein Auto: 2007 x5 3.0...2009 328i
Hey there, sptt144. I would also check the coolant reservoir. I had to replace one on my x5...it is an easy fix to do yourself
Old 02-24-2013, 05:19 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Yes, if it's leaking. You should see dried solids where a leak occurs.
Does your car put out more than normal white fog on cold start? Smell sweet?
Old 02-24-2013, 12:59 PM
fun2drive's Avatar
BMWCCA 149159
Mein Auto: 335 vert/14JGC/ 17Outback
Be really careful with this because it takes only one overheat to blow a head gasket.
You need to investigate the source of the leak. If you have the plastic pan on the car you need to remove it and locate the source of the leak unless it is obvious. If you can't find it buy some dye which most autoparts sell and put it in the coolant. It will show a bright yellow-green color unmistakeable...
Old 02-24-2013, 10:24 PM
sptt144's Avatar
Hope all it is, is the coolant reservoir!
