E36 (1991 - 1999)
Old 01-26-2013, 06:06 AM
lupo91 lupo91 is offline
Mein Auto: 1998 bmw 318i e36
help my car wont start
hi all my car has been off the road for just over a year now, i got it started first turn off key was running nice took it for mot went back to pick it up and it wudnt start,
bumped it off and it drove home fine
but as soon as i turned it off and went to re start i get nothing i can here fuel pumps so i know its not that
starter motor should be fine as i have changed that
i now also have a problem with my electric windows they work on the first turn off key but when you turn it again they go off
iv checked all the fues's and relays under bonnet
any ideas
is a 1998 bmw 318i 1.8 16v e36 model
Old 01-26-2013, 09:42 AM
hornhospital's Avatar
D'oh, You Kids!
You need to describe the no- start issue more clearly. Does the engine spin when you try to start it, or do you get nothing but the dash lights on and the sound of the fuel pump running?
Quotes to live by:
Old 01-26-2013, 04:40 PM
yes all i get is dash lights and can here fuel pump, it dosnt spin or anything but if i bump it its fine and runs nice
Old 01-26-2013, 05:16 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
check the battery. bet it is dead.
df
Old 01-27-2013, 03:44 AM
its got new one on
Old 01-27-2013, 07:32 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Check your starter relay.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-27-2013, 03:43 PM
BMR_LVR's Avatar
Humble E34 lover
EDIT TO THE ABOVE POST: My bad. I just realized that the starter relay is for automatic transmissions only.
OP, is it possible that your clutch safety switch is faulty?
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-27-2013, 05:09 PM
well, if the battery is new then i would double check the connections to make sure there is no excessive resistance in the circuit. many times just because the clamps are tight doesn't mean that you have a solid connection. a voltage drop test would be the best way to check this. if there is an indication of high resistance then that needs to be addressed.
df
Old 01-29-2013, 02:04 PM
right just an update i been and bounght new starter as i put a used one on i had laying around and iv also been and bought brand new battery best i could get
fitted starter and tried it befor bolting box and prop back in and it started first turn
i then bolted box back in and prop went to start it again and its the same wont start ??
so now thinking its a problem on wireing to starter any ideas ?
Old 01-29-2013, 02:35 PM
bimmerbarbie's Avatar
bimmerbarbie bimmerbarbie is offline
Official Queen of E36 OT
Send a message via AIM to bimmerbarbie
Mein Auto: 93ish 325ish
df
Did you try doing this? Did you try the other suggestions? A new battery and starter won't do you much good if the connections to them aren't working properly.
Originally Posted by E36 Phantom View Post
... We all kinda just ignore Amber (barbie) anyway. She's sort of our attitude and eye candy here, that's why we keep her around...
Old 01-29-2013, 03:27 PM
no wasnt sure how to
Old 01-29-2013, 03:47 PM
here....
http://on.aol.com/video/how-to-volta...-car-158075314
df
