E46 (1999 - 2006)
Old 01-21-2013, 09:30 AM
Phil123 Phil123 is offline
Mein Auto: E46 323i
No clutch peddle
Car won't go into gear when started but it will drive if I start it in gear but when I do this I can't Change gear any ideas
Old 01-21-2013, 09:44 AM
lgr122 lgr122 is offline
Mein Auto: '00 e46 M43, '05 e87 M47
How about brakes?
Brakes and clutch share fluids, so if there's something wrong with that brakes should feel it also.
Old 01-21-2013, 09:48 AM
Mein Auto: E46 323i
Brakes feel very good
Old 01-21-2013, 10:42 AM
1972ford's Avatar
1972ford 1972ford is offline
Function over fashion
Mein Auto: 325xiT
You can start it in gear?? With the clutch in or out?
Old 01-21-2013, 10:50 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Probably a hydraulic problem. Bleed the clutch slave cylinder and see if it improves anything.
The road goes ever onward....
(R.I.P. Jever)
Old 01-21-2013, 10:51 AM
Mein Auto: E46 323i
With the clutch out
Old 01-21-2013, 11:50 AM
Fast Bob's Avatar
Keeping it surreal
Originally Posted by Phil123 View Post
With the clutch out
If you can start the car *in gear, with the clutch out*, among other things, it means that your clutch/starter interlock switch is bad.
(R.I.P. Jever)
