knock sensor ohms - Bimmerfest - BMW Forums
Old 01-21-2013, 05:32 PM
wolfbone71 wolfbone71 is offline
Mein Auto: 1998 540i
knock sensor ohms
Is there any way to test the resistance on a knock sensor? I want to make sure they are faulty before I replace.
Old 01-21-2013, 07:06 PM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Are they giving you any codes, if not they should be good.
They are piezoelectric devices, not sure you can get an ohm reading from them.
2000 540/6 Slightly tweeked...everywhere
Old 01-21-2013, 07:59 PM
geargrinder geargrinder is offline
Crapparatus Bendgineer
Mein Auto: E46 M3Cic6MT, E39 540iT
Correct but they need to be torqued very specifically. Sometimes you can retorque them and theyll work fine. I like to remove and clean the mounting area, then retorque. Never done an E39 but its worked on other cars...
2003 M3CicM6 TiAg
2002 540iT 6MT Sport TiAg
1995.5 Audi S6 Avant (utility/winter billetturbobattlewagen)
2008 Audi A3 2.0T DSG (hers)
1999 Cherokee Sport 4L (trailer-hitched in-law loaner bomber)
Some Stuff FS
Old 01-22-2013, 03:57 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Dunno if it adds any value, but I typed /knock sensor F3 in the bestlinks and this came up which may be of some help:
- How to better understand the piezoelectric knock sensor operation (1)
Originally Posted by Flug540 View Post
I finished rebuilding my sensors over the weekend. Wasn't too bad, the first one took the longest time while I was trying to figure out the best technique. Below are some photos of the process and what they look like now. On the first two photos you can see what happens to the original internal insulation when you pull the outer shell. Resistance on all sensors actually gone up slightly, now it's about 4.98 MOhm, which I think shows that the original insulation already was beginning to conduct.
Old 01-22-2013, 06:52 AM
Cool post. I've never seen that bad insulation deterioration that's for sure! Interesting that the Bosch knock sensors look exactly the same as every other European car I've ever seen one on... I wonder if they are all identical just with different end connectors.
2003 M3CicM6 TiAg
Some Stuff FS
Old 01-22-2013, 11:29 AM
bluebee's Avatar
I wonder also.
What would be nice, if someone gets a chance, is to snap a photo of the knock sensors in situ, on the engine, so that I can post it to this engine thread:
- Getting to know your M54 engine, a photo & identification guide to every visible part in the engine bay (1)
