Old 01-22-2013, 07:18 PM
Tiko530 Tiko530 is offline
Mein Auto: 2003 530i
Flickering HID's
Had my driver side lowbeam go out a few weeks ago.
Had the car in the shop for new struts and I had them put a new pair of Xenon lowbeams. Had a pair of aftermarket HID lowbeams bulbs put in and was told the driver side ballast would need to be replaced as well. Took the car home and a few hours later on start-up the PASSENGER side flickered then turned off. Turned the car off and back on and it worked this time. Happened again later on startup, turned headlight knob off and back on and it worked. Does this mean my other ballast is on its way out too or could an improper installation of the lowbeam have caused this?
Old 01-22-2013, 07:52 PM
LalaRay's Avatar
LalaRay LalaRay is offline
Boosted
Mein Auto: 03 ///M5
Buy from http://ddmtuning.com/ wont have those problems.
2003 ///M5. ~ Jet Black/ Le Mans Blue
RK Supercharged @ 501wheel horsepower
Supersprint Headers,
Evolve Alpha N Tune,
CNS lightweight dm flywheel/Spec clutch,
ST coilovers,
Eibach Rear Sway bar/Beast Power Brackets,
Drilled slotted Rotors/Akebono Euro pads,
Magnaflow 14816 Mufflers
_____________________________
Old 01-22-2013, 08:55 PM
Good advice for next time. Just trying to figure out if its a coincidence that my right ballast starts going bad now or could it be a bad installation of the new bulb or the bulb itself?
Old 01-23-2013, 04:23 AM
dtadrian's Avatar
dtadrian dtadrian is offline
BMW's are like women. $$$
Mein Auto: 1994 540i
Most likely your ballast. But make sure the power to ballast has clean non corroded connectors.
1999 528iT Sold
1994 540i Toy
2014 Jetta Turbo APR stage 1 daily driver.. FUN!
Old 01-23-2013, 10:39 AM
Thanks. Don't see any corroded connectors. Problem seems to have gone away, though I have a feeling it will be back soon enough.
Old 01-23-2013, 11:04 AM
BentValve's Avatar
BentValve BentValve is offline
Mein Auto: 00 528i 3 pedals
It will be back, typical symptom of a failing ballast.
