1998 540i M62 Water Pump - Bimmerfest - BMW Forums
Old 05-20-2012, 09:13 AM
MurrayP MurrayP is offline
Mein Auto: 98 540i
Just replaced my water pump in the last couple of weeks (along with all other cooling system components since I had a leaking valley pan gasket and high milage). I used the BMW OEM version with the plastic impeller (metal impeller was out of stock and not available). My old water pump was fine and did not make the noise this one is making. What do you think - is this a warranty claim??
Old 05-20-2012, 10:32 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Are you sure it's coming from the water pump?
Bring it back to BMW, 2 yr warranty on parts.
Years ago I bought a new WP from BMW. It had a slight squeak when idling at 500 rpm. If you turned on the AC the idle goes up to 700 RPM and the squeak goes away. BMW gave me a new pump and even offered to install it for free.
2000 540/6 Slightly tweeked...everywhere
Old 05-20-2012, 11:36 AM
Mein Auto: 98 540i
I purchased about $1,500 of parts from an online house in CA that makes the boarder to Canada easy. They are very good but I don't see them listed as a site sponsor so I won't advertise them. It started with the valley pan, CCV, VCG, water pump, thermostat, spark plugs and all hoses. Got her all back together, overfilled the expansion tank (didn't pay attention to the proper process) and quickly burst (on 1 mile test drive) the radiator hose at the famous driver side upper hose connection point.
Yes, I know, I've read it a thousand times here, you have to do a complete cooling system overhaul...
So, I ordered the fan, clutch, expansion tank and radiator. Installed them this weekend. Used the special BMW blue coolant (for a second time). Bled the system properly this time and all appears to be well...except for this ticking water pump! I'll send a link to the video to the parts house and see what they have to say.
I've never wrenched on a car before but all the help on this forum in particular gave me the stones to try. The day I got the car in Toronto last July, I droped by the BMW dealer closest to me (2.5 hrs away from my home but was on the way home from Toronto) and spent $170 on an oil change. Had I had all of the above done at that same dealer, I suspect I would be out $3-$4K by now.
I got pricing on some of the parts from that dealer (Endras) and they were x4 in comparison on some of the parts I purchased in CA. The difference was staggering! I got the coolant from Endras (twice) in the last few weeks and bought oil and a filter kit - $90 friggen bucks yall for 8 quarts!
Yes I know, reasonable to buy, expensive to maintain! Lot's of fun though!
Old 01-30-2013, 11:18 PM
killahbeatz killahbeatz is offline
Mein Auto: 540i
MurrayP did you ever find out if it was the pump. I just installed a new water pump and it did the same noise. I drove it for an hour and the noise was gone. I am going to see if it still make's that noises in the morning. I'm thinking that I tighten the belt tension to tight
