F30 / F31 / F32 / F33 (2012 - current)
The sixth generation 3 series, chassis code F30. 2013 model year 328i and 335i sedans now in production. Read the F30 frequently asked question thread for all your basic question and dive into all the details in the ultimate F30 information thread. |
#51
Planning to test drive rwd today. . Lil snow on the ground..
2013 335i M-sport xDrive 'Superman Combo' Cold Weather Pkg, Dynamic Handling Pkg, Premium, Technology, Sport auto, Rear-view camera, Park Distance Control, HK ![]() ED: May 28, 2013 PCD: Later.. Enduring painful ED wait....
#52
The traction control will prevent a moment of the rear fishtailing unless you go into Sport + mode or turn of the DTC. Although I have AWD, I am not sure if Sport + mode disables the front wheels or not (maybe I will try on the next snowfall). I am sure someone else could answer that question. If it did disable the FWD portion of the AWD, then you could have the best of both worlds. Sunny5280 is correct as the AWD 335 is 0.2 tenths faster from 0-60 times due to the initial launch from a stop (4 wheel traction instead of 2 wheels), but after you get rolling a little, the RWD would outperform due to weight (AWD is 155 lbs heavier) and friction (extra drive components for the front drive). The AWD is very good and you would not be disappointed!
Kenneth P. Gray 2013 - 328i xDrive Sport, Imperial Blue/Everest Grey Dakota Leather ![]() 2010 Cadillac SRX Performance, Platinum Ice/Ebony (Wife's drive) ![]() 2013 328i xDrive / 8-Speed / Imperial Blue / Everest Grey / Sport Package / Premium Package / Tech Package / Heated Seats |
#53
It was Camaro V6.. arnd 320hp..
#54
GM has perfecting this system for many years and has it down. On its more performance oriented cars, the system allows a bit of nonsense before kicking in depending on the aggressiveness of driver input, speed, etc. Corvettes have had this for many years. As to the point, xDrive does not allow steering with the throttle. Additionally, it will understeer if given too much power with stability control off. |
#55
Let us know what you think. Yours is a difficult case as it's not as clear cut one way or the other.
#57
1) Replace my summer tires with All Seasons indefinitely and save $$$ on paying for storage to store the 2nd set of tires 2) Get a set of snow tires which will be in storage when not in use. Which would you recommend for the area climate? I've seen snow/ice more times in my couple of weeks in DC then almost an entire winter in NC.
2013 335i Sport | Mineral White | Leather Dakota Everest Grey | Cold Weather Package | Driver Assistance Package | Premium Package | Technology Package | Auto high beams | Parking Assistant | 6MT My 335i Photo Gallery |
#58
#60
I am feeling more and more convinced every minute that I want to have rwd... will have a set of snows to swap in winters...
#61
#62
In Delaware I'd get performance snows (like Dunlop M3) rather than hardcore snows (Blizzak or Nokian Happa). Hardcore snows are very rumbly and don't handle well.
"When you were born, you cried and the world rejoiced. Live your life so that when you die, the world cries and you rejoice." - Cherokee Expression |
#63
If he wants RWD, then he should keep a dedicated summer and winter tire. If he wants AWD, he may be able to get away will all seasons, but he would have compromised performance year round versus having dedicated summer and winter tires. I fail to see how wanting dedicated tires would change your recommendation to AWD.
ED - 5/13/2013 See my ED planning thread here and help me plan my trip!
Future 2013 335i Sport Line PPK| Alpine White/Coral Red | ZDH | ZCW | 2TB | ZTP | ZPP | 508+3AG | 5AC |
#64
#65
#66
2011 328xi. Space Grey, Beige Dakota Leather, Premium pkg., Value pkg., NAV, SAT, Heated SW, Steptronic,
#68
If you don't notice the difference then more power to you.
#69
It's not a matter of noticing the difference or not. It's a matter of how does the OP plan to drive the car? Does he plan to use it as a daily driver with occasional spirited driving? Does he plan to use it as a daily driver and then take it out on the twisties every weekend? Will it be a secondary car that he takes out to drive through the twisties, kicking the rear end free as the urge arises? Is he going to track the car (we already know he has no intention of doing this)? What are his driving skills? Does he possess the skill necessary to push the tires to their limits thus requiring a use specific tire?
What 3284me and I are saying is the majority of drivers plan to use the vehicle as a daily driver with maybe an occassional stint of spirited driving. Occasionaly being defined as not enough to make a difference between RWD versus AWD, dedicated performance tires versus all seasons, sport suspension versus non-sport suspension, etc. It is also my opinion the vast majority of drivers do not possess the skills necessary to push the vehicles to their limits. I suspect the OP, and the vast majority of people who ask about RWD versus AWD fall into this category. This is my general rule of thumb. |
#71
I live in Vermont with AWD. The is the only reason I have it is I live on a dirt road that goes up a 11% grade for close to a mile before I get to my house. If that was not the case I would have bought a RW car. There are plenty of cars in New England that have RW drive cars with 4 snows for the winter and do just fine. Buy the RW car and move on with life for all the reasons stated in the other posts. Just my 2 cents...
PSS|PPK|PE|LUX H8 V4 EYES Pending
#72
I lived in Philadelphia before. The weather is enough for snow tires. I had studded tires, which is overkill. Studded tires are actually worse in cold, dry weather. |
#73
You'll need to take this up with the OP as he's the one who stated he's going to obtain winter tires.
I can readily tell the difference between such tires within a block of normal non-aggressive driving. I would expect most to notice the difference merely commuting within a day or two at most. (The difference between dedicated snows and high performance are easily detectible upon backing out of the garage after making the swap - dedicated snows feel like marshmallows.) |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
