Old 09-20-2011, 04:15 PM
guinnessman7 guinnessman7 is offline
Mein Auto: 2009 328 i
fuse for cigarette lighter
can someone please tell me the fuse location for the cigarette lighter in a 2009 328 i
thanks
Old 09-20-2011, 06:38 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
Unfortunately, from what I understand most BMW models have variants on the fuse panel within models and model years. Your best bet is to get the fuse card, which should be clipped to the panel cover.
Look for a symbol representing the lighter. It's typically:
minus sign THEN half circle with dot in center connected to arrow going right THEN plus sign.
There will be a number next to the symbol. That's the number of the fuse to pull. A diagram will show which number relates to which slot on the panel.
The attached image on this post : http://www.bimmerfest.com/forums/sho...54&postcount=2 shows the fuse symbol in the lower right from my fuse card. For my car, it's fuse #8, but someone can't guarantee you with any certainty what your number is without your fuse card, even if they're the same model and year.
If you don't have the card, this post: http://www.bimmerfest.com/forums/sho...78&postcount=4 gives you some ideas on how to track the fuse down.
George
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 09-20-2011, 08:38 PM
Nordic_Kat's Avatar
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
For my MY09 328i E93 the cigarette lighter per Zooks description is #8.
See attached.
BTW: What are you attempting to do?
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien| BMWCCA#445793
Old 01-23-2013, 04:11 PM
sonnysBMW sonnysBMW is offline
Mein Auto: 325i
cig lighter
Thanks so much for the info,I could not figure out the hieroglyphic symbols,any way problem solved ,thanks to your info!
