E34 (1989 - 1995)
Old 01-22-2013, 11:53 AM
bmr95 bmr95 is offline
Mein Auto: 1995 bmw 525i
e34 no heat
Hello all
Pretty new to this forum. so excuse any obvious things that i mention/miss.
I have a 1995 bmw 525i (e34) and found out yesterday the heater is not putting out any heat. The fans work but blow out cold air. Also the Temp. gauge gets to middle when idel but when I drive on highway (65mph) in cold weather it drops to where the blue mark is...
Should the temp gauge be middle during driving conditions? I think once I figure out the why the gauge isnt staying in the center while driving, that will also fix my heating issue.
any advice would be appreciated.
EDIT: Thank you for your replies. Yesterday I did let the car heat up at idle until the temp. gauge reached middle, then turned on the heat...and it was just barely warm not as hot as I expected.
Old 01-22-2013, 11:56 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Sounds like your thermostat has stuck in the open position.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-22-2013, 12:05 PM
BMWFatherFigure's Avatar
Old School
or sticks open now and again - replace it anyway...
Current:
Previous:
Old 01-22-2013, 08:40 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
+1
on the bright side, its not overheating...
Old 01-23-2013, 07:00 AM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 2000, 1995 540iA, 07 525
I concur with the thermostat replacement. When I had the same issue, I found that my thermostat was broke and stuck in the open position. It took care of my no heat issue. Also, you may have a clogged heater core but that can usually be flushed out. Good luck and let us know it that works for you
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 01-23-2013, 07:18 PM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: 535i
I agree with the thermostat. The fact that the engine cools at highway speeds proves it bad.
You may also have a problem with the aux coolant pump. If it is not working very little warm coolant will flow through the heater core and your heat will be weak.
Blocked system was also mentioned. How long since the last coolant flush?
Winter Rules
Old 01-24-2013, 10:54 AM
I have had the car for about a year and month have just added coolant have not flushed the system. Hopefully its is something I can do myself. Also can someone recommend which thermostat I should get (manufacturer and where i can purchase)? And coolant type that I should use. I heard we need a special BMW coolant..is that true?
1995 bmw, cold air, cold weather, e34, heat
