Old 01-22-2013, 01:54 PM
SamS's Avatar
SamS SamS is offline
Mein Auto: 2013 ActiveHybrid 3
Rear head rest removal?
Has anyone successfully removed the rear head rests? I pulled them all the way up, but they won't budge. And they don't have that tab near the base/post.
I need to remove them to accommodate car seats. For a front-facing full-size seat, you have to extend the rear headrest to the maximum height to clear the seat. At the max height, this creates quite a visible blockage out the rear window.
Old 01-22-2013, 04:04 PM
stom_m3 stom_m3 is offline
Mein Auto: Toyota Sequoia
I just pulled mine for our car seat. I had to fold down the seat to do it though. The headrest fully extended hit the roof. Came out no problem. That said, I have not tried the middle one.
Old 01-22-2013, 04:35 PM
SamS's Avatar
Crap. I already installed the car seats. So, you just fold down the seats, and they'll pull straight out?
Old 01-22-2013, 07:19 PM
Did in mine. I have not tried the middle one though...
Old 01-22-2013, 08:01 PM
KLC KLC is offline
Mein Auto: '13 335i Sport
There's a section in the owners manual on this. I can't remember where and don't have access to it at the moment, though.
ED - 5/13/2013
PCD - 7/17/2013
2013 335i Sport Line PPK | Alpine White/Coral Red | ZDH | ZCW | 2TB | ZTP | ZPP | 508+3AG | 5AC
Old 01-22-2013, 09:06 PM
SamS's Avatar
You are correct! The manual indicates to raise the head rest as far as possible, the press in the tab near the stalk. This only works if the seats are folded down! Otherwise there is not enough clearance for the head rest to raise that high.
So, after an hour of sweating, I pulled out both car seats, folded down the rear seats and was able to remove all three head rests and re-install said car seats.
Moral of this thread: remove head rest before you start on your car seat project
Old 01-23-2013, 06:33 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
I would say the "moral" of the story is to read the manual.
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 01-23-2013, 06:43 AM
SamS's Avatar
cheers
vern
Uh, no.
In the manual it says nothing about having to fold down the rear seats. Only to raise them and press the side button. When you do this, there is not enough clearance to pull them all the way out, and you can't tell just how much more clearance you need from the roof.
Old 01-23-2013, 12:46 PM
jfox335i's Avatar
jfox335i jfox335i is offline
Mein Auto: 2014 335i
Uh, no.
Hmmmm. I took off the middle head rest without moving the seat at all. I found it obstructs the view out the rear window. Much better now that it's off.
Current: 2014 F30 335i Melbourne M-line, PP,CW,6MT,NAV,DA,403M
2012 Z4sDrive35i - BSM,Coral Red,Msport,PP,Tech,CW
Retired:
2012 F30 335i Sedan - BSM, Sport Line, PP,Tech,HK,CW,DA2
2010 E90 M3 - JBM PP,TP,ES,CW,Beast
BMWCCA #471315
Old 01-23-2013, 12:49 PM
SamS's Avatar
Center rear headrest is different/smaller, and of course comes out regardless of seat position.
It's the L/R ones that give you trouble, and the ones you'll need to remove to install a forward-facing car seat.
Old 01-23-2013, 04:30 PM
EddieB's Avatar
EddieB EddieB is offline
Mein Auto: '13 335i M-Sport 6sp
I need to take out the middle so I can use my E46 seat cover. 2002 E46 only had 2 head rests.
F30 Sapphire Black 335i 6MT|2PE|4AB|ZDH|5AC|LCSW|ZMM|ZPP|ZCW|ZDA|ZDB|ZTP|4 15|688 Dinan Stage 1 Suspension and Shockware ECU tune
Previously - F30 335i, E46 M3, E39 530i, E46 325i
