E36 (1991 - 1999)
Old 01-22-2013, 03:15 PM
yxd0018 yxd0018 is offline
Send a message via MSN to yxd0018
Mein Auto: 328i
first DIY oil change
Yesterday I did my first DIY oil change on my 1998 328i. I used a ramp and use precaution measures such as wheel choke and jack. It went ok. I thought I tightened the drain bolt but when I checked this morning, there is a large oil leakage under the car. Because the bolt is so small and thread is very short, like 2-3 rounds so I don't want to put too much torque onto it. But I did tighten it more.
Now I have 2 issues.
1. even after tightening, after a day parking, I see some oil accumulated under the bolt. It's not dripping yet to the ground. Should I tighten it more? Will it break the thread?
2. When I first start the car in the morning, I heard some high pitch noise. it sounds like metal scratching. After heating up, the sound went away. Now at 6pm, I hear it again when starting the car.
I added 7qt oil in the oil change and see the oil level in the middle of dip stick or whatever it's called to measure the engine oil level. Thinking of the leakage, I add 1/2 qt more now.
During oil change, I found it difficult to screw back the oil filter cap but I managed to put it on.
Besides above 2 points, I cannot think of any reason oil change can cause the high pitch noise.
Any suggestions? Should I reopen the filter cap to take a look? Should I ask mechanic to take a look?
Edit: I will record the sound later.
Old 01-22-2013, 03:24 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Did you replace the crush washer on the drain plug?
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 01-22-2013, 03:29 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Originally Posted by E36 Phantom View Post
Did you replace the crush washer on the drain plug with the new one that should have been provided with the new oil filter?
Fixed.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 01-22-2013, 03:33 PM
I Am The Machine
Just like the "u" you Canadians throw in everywhere, you just like making everything longer when it needn't be...........eh?
// Chad //
You're a derbanana
Old 01-22-2013, 03:34 PM
Mein Auto: 328i
Damn, I see it in the package, but not in my drain plug so I didn't. What can I do now?
Old 01-22-2013, 03:37 PM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
You will have to drain the oil and refill after you put the crush ring on the drain.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
Old 01-22-2013, 03:39 PM
Mein Auto: 328i
k, thanks. what about my #2 issue?
I Am The Machine
If you completely clean and dry your drain pan you can reuse the new oil. Just do like you did before. Also, you know to let the oil rest in the block for 5-7 minutes before checking the oil level, right?
// Chad //
You're a derbanana
Old 01-22-2013, 03:40 PM
jonesin's Avatar
The Canadian Prick.
So long as your catch can is clean, you can safely reuse that oil though.
Old 01-22-2013, 04:15 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Take the filter out and put it back in. Make sure all the O-rings are seated properly.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 01-22-2013, 06:35 PM
hornhospital's Avatar
D'oh, You Kids!
OP said the plug only went in 2-3 turns before getting tight. That's not right. The oil plug goes in at least 8-10 turns if not more before it pushes the crush washer against the oil pan drain surface. I believe what we have here is a cross-threaded plug. That would explain the leak, too. No matter how tight you pull it, the crush washer is never going to seal the plug, since the plug isn't perpendicular to the sealing surface.
Quotes to live by:
Old 01-22-2013, 06:51 PM
Only one way to know for sure. OP, (that's original poster) we are gonna have to get a picture of that plug. And post it here please.
Old 01-22-2013, 06:55 PM
Mein Auto: 328i
disaster, the thread of the plug is whacked a little bit. I will post picture shortly
Old 01-22-2013, 06:59 PM
Hellawut??
Mein Auto: who knows?
good call by the old ken!
-Franklyn
Old 01-22-2013, 07:13 PM
Mein Auto: 328i
plug is here. I torque too much. Nextby is the washer coming with oil filter. http://sdrv.ms/SyP3nB
You can see the broken point of thread close to the top.
What should I do? buy new one from dealer or any garage will have this plug? I'm afraid if I put this on and it will leak again and I have to drain the oil again. I didn't feel the same tightness as the first time.
Hellawut??
weld a patch over it. done right?
picture is broken
-Franklyn
Old 01-22-2013, 07:19 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
That's what I thought would end up being the case.
1998 BMW 328is
1966 Pontiac GTO
Old 01-22-2013, 07:36 PM
Mein Auto: 328i
hmm, I can see the picture even logging out of skydrive. You don't?
Old 01-22-2013, 07:40 PM
Mein Auto: 328i
picture from google drive. https://docs.google.com/file/d/0BymM...pzUWlYVFk/edit
Suggestion please. I was outside with gusty wind and minus degree.
Old 01-22-2013, 07:43 PM
ZeGerman's Avatar
Warm Leatherette
I saw it just fine. The drain plug is sheared right off.
1998 BMW 328is
1966 Pontiac GTO
Old 01-22-2013, 07:44 PM
Mein Auto: 328i
it seems the introducing small thread is broken but the main thread is still there. How much should I tighten up to make sure it doesn't leak? I wish I haven't redone it.
Old 01-22-2013, 07:46 PM
Mein Auto: 328i
I feel it tighten a bit then loose again. Did I destroy thread in the oil tank?
Old 01-22-2013, 07:54 PM
Mein Auto: 328i
Should I tighten it up to its first resistance to see if it leaks. Just like last time, if it leaks I will tighten more? Never thought the plug has so little thread.
Old 01-22-2013, 07:55 PM
ZeGerman's Avatar
Warm Leatherette
The plug is supposed to have many more threads. You need a new drain plug. Either you or a previous owner over-tightened the plug, and my guess is that it's floating around inside your oil pan (not good).
1998 BMW 328is
1966 Pontiac GTO
Old 01-22-2013, 08:08 PM
Mein Auto: 328i
I saw oil pan plug online http://sdrv.ms/XWkfwe
Does all E36 have the same plug? The plug I have doesn't seem to be broken as the surface is very smooth.
