E30 (1982 - 1993)
Old 01-22-2013, 03:46 PM
beaverphant beaverphant is offline
Mein Auto: 1990 325i
Sunroof won't close
I have a 1990 325i and the sunroof is stuck open. The motor will pull it all the way open but then it will only shut like 10 percent before the motor stops. I was messing with fuses the other day. It's been a super cold winter (It got above 20 F for the first time in weeks). Any suggestions? And please don't say take it in.
Old 01-22-2013, 06:20 PM
hornhospital's Avatar
D'oh, You Kids!
Lube the tracks with white Lithium grease (CRC makes a spray version, available at most auto parts stores). Manually run the sunroof closed with the hex wrench in the tool kit. Wait for warmer weather, then tackle a proper fix.
Quotes to live by:
Old 01-22-2013, 09:10 PM
e30325i e30325i is offline
Mein Auto: 1989 325i
i second this
Old 01-23-2013, 08:12 AM
Could it be the cold that is causing it? It sides open but not closed. The temp constantly been in the teens and single digits fahrenheit? If so any ideas to warm it up? I don't have a garage.
Old 01-23-2013, 08:48 AM
cold cld b messing with the motor its plausible..you cld try using rly hot water and seeing if theres any ice down in it somewhere..but id try cranking it in manualy n see when you get past the mark that it doesnt close automatically if it hits anything or you feel anything...im not sure how the auto works cus mines manual but maybe it slipped off track...cranking it in manually mite fix this or let you know if it did or not..have you tried it with the car cranked?..if not then maybe the car battery is weak from the cold n it needs some juice
Old 01-23-2013, 09:07 AM
Great ideas! How would one go about cranking the window shut manually? I Would wait to fix it but its 7
Old 01-23-2013, 03:31 PM
may look alot like this
be careful tho dnt wanna strip it out
is the switch right in from of the sunroof? if it is you may have to take it off n see if theres a little hex thing you can put a tool around or into like a allen wrench..thats what i would think and on mine which is manually thats how it works you have a little handle and you spin it so i wld think yours wld be like that under the auto switch but dnt quote me lol
Old 01-26-2013, 03:50 PM
BMWFatherFigure's Avatar
Old School
All the info about the sun roof is in the hand book.
Current:
E38 Parts Car
Previous:
Old 01-27-2013, 03:38 AM
onager onager is offline
Mein Auto: 87 E30 325i
If there is a hair dryer around you could set it on low heat so not to melt any plastic and let it blow towards the guide rails.
e30 325i, sunroof open/close issue
