E60 (2004 - 2010)
Old 01-22-2013, 05:46 PM
schpenxel schpenxel is offline
Mein Auto: E60 - 545i
Rough idle on start up on 2004 545i (only when under 40*F)
So--the cold weather is starting to sit in around here and a rough idle issue seems to get worse the colder it gets. Seeing as how we're under 20*F tonight, I have a feeling tomorrow will be the worst.
Anyways, on to the issue:
Basically when I start the car cold (only happens when engine is cold and outside temperature is under somewhere around 35-40*F) it idles pretty rough, RPM's jumping around some at first. It's never cut off from this, but the fluttering is a little embarrassing when any one is in the car with me. It set off the check engine light to day, and the codes basically said cylinder misfire detected and it had a code for every cylinder, so I would think that rules out the coils. After I start driving, it seems to stumble a little bit under the first acceleration of the day, but after I accelerate once I've never noticed it again.
I've had it set off the check engine light once before a month or two ago but it hasn't been cold enough since then to have any issues.
I have found a few service bulletins on similar type issues.. one being this one: SIB 11 02 05
I cleaned the MAF a few months ago with no change.
Any other ideas? That bulletin does not apply to my build date (December 2003). It's so strange that if it's 40*F outside it runs fine, 35*F and it stumbles and jumps all over the place at first. Only seems to happen first start of the day but it also only sits a few hours at a time so I doubt it cools down all the way.
I'll try to find all the codes again in a minute to post them all up for all to see. I have 185K miles at this point, so I'm just glad it still goes :lol:
Any ideas??
Old 01-22-2013, 05:59 PM
Here are all the codes except an e-box fan that I didn't bother putting on.
Code:
274E CDKMD - Misfire detection, Checksum failure
P0300 Verbrennungsaussetzer erkannt - mehrere Zylinder
Error counter: 3
Logistic counter: 39
1. Umweltsatz
Mileage 296200 km
Engine speed (nmot) 760.00 /min
Relative air filling (rl) 33.00 %
Engine temperature (tmot) 18.75 degrees C
Tank fill level (tfst) 19.00 l
2. Umweltsatz
Mileage 296424 km
Engine speed (nmot) 880.00 /min
Relative air filling (rl) 22.50 %
Engine temperature (tmot) 15.75 degrees C
Tank fill level (tfst) 52.00 l
3. Umweltsatz
Mileage 296672 km
Engine speed (nmot) 1120.00 /min
Relative air filling (rl) 25.50 %
Engine temperature (tmot) 21.00 degrees C
Tank fill level (tfst) 25.00 l
Implausible signal or value
Test conditions fulfilled
Error not present now, but already stored
Error would cause a warning lamp to light up
Diagnostic active
Error in debounce phase
Error code: 27 4E A8 21 03 00 03 27 90 A1 13 2C 59 13 90 BD
16 1E 55 34 90 DC 1C 22 5C 19
2743 CDKMD01 - misfire detection cyl. 5
Error counter: 1
Logistic counter: 27
Mileage 296200 km
Error not occurred yet
Diagnostic active
Error code: 27 43 88 01 00 00 01 1B 90 A1 13 2C 59 13 FF FF
FF FF FF FF FF FF FF FF FF FF
2747 CDKMD05 - misfire detection cyl. 3
Error counter: 2
Logistic counter: 37
1. Umweltsatz
Mileage 296200 km
2. Umweltsatz
Mileage 296672 km
Diagnostic active
Error code: 27 47 88 01 00 00 02 25 90 A1 13 2C 59 13 90 DC
1C 22 5C 19 FF FF FF FF FF FF
2748 CDKMD06 - misfire detection cyl. 7
P0307 Verbrennungsaussetzer erkannt - Zylinder 7
Error counter: 3
1. Umweltsatz
Mileage 296200 km
2. Umweltsatz
Mileage 296424 km
3. Umweltsatz
Mileage 296672 km
Diagnostic active
Error code: 27 48 A8 21 03 07 03 27 90 A1 13 2C 59 13 90 BD
2744 CDKMD02 - misfire detection cyl. 4
Error counter: 1
Logistic counter: 31
Mileage 296424 km
Diagnostic active
Error code: 27 44 88 01 00 00 01 1F 90 BD 16 1E 55 34 FF FF
2746 CDKMD04 - misfire detection cyl. 6
Error counter: 1
Mileage 296424 km
Diagnostic active
Error code: 27 46 88 01 00 00 01 1F 90 BD 16 1E 55 34 FF FF
2742 CDKMD00 - misfire detection cyl. 1
Error counter: 1
Mileage 296672 km
Diagnostic active
Error code: 27 42 88 01 00 00 01 25 90 DC 1C 22 5C 19 FF FF
Also, forgot to mention that I replaced the CCV valves a few weeks ago and zip tied all of the connections so they are as good as they were to begin with. Regardless, the problem was present prior to changing those out. I noticed no change afterwards.
Old 01-23-2013, 04:49 PM
And what do ya know.. today was the coldest day of the year and it didn't give any problems at all. No rough idle at all.
Weird.
Old 03-04-2013, 07:05 PM
Davegsu Davegsu is offline
Mein Auto: 645 ci
I'm having the exact same issue with my '05 645ci. Does anyone know if we share a similar engine?
Old 03-04-2013, 07:07 PM
Yes, we do
One thing I've noticed on mine is that it seems to be worse when it's just above freezing. I wonder if some sort of condensation is forming somewhere and causing some sort of issue? It's still so odd to me that I can start the car in sub 20*F weather and it has no problems whatsoever, but start it on a morning when it's 35*F and it runs like crap for a mile or two
(N62 engine)
Old 03-04-2013, 07:28 PM
Mein Auto: 645 ci
Yep, that's the same engine alright. It only happens between 35-45'
Old 03-04-2013, 07:30 PM
Mein Auto: 645 ci
What did you eventually do to solve the problem? It threw up a SES and increased emissions error for me.
Old 03-04-2013, 07:42 PM
I haven't figured it out. I've found that if I don't let it sit and idle and just start driving as quick as I can, it doesn't throw the increased emissions error or SES light, so that's what I've been doing. Once I get out of the parking lot and accelerate once or twice, it does fine the rest of the day (even on days where it sits for 12 more hours and it's in that "trouble" temperature range, it still starts fine the second time of the day. Weird.)
Old 03-04-2013, 07:49 PM
In another thread they mentioned the CCV system, which I have replaced already. May be an option for you?
I believe it's either related to a vacuum leak that is more evident when the car is cold due to the valvetronic system behaving more like a "normal" system and using the throttle body for the first 90 seconds of running
or
intermediate shaft geometry on valvetronic system issues. There was an SIB for this. Not cheap to replace at all but the symptoms fit pretty much exactly
or
some sort of electrical / coil / plug issue where condensation is causing intermittent contact which is causing a misfire either due to lack of spark or fuel. I'm leaning away from this one since it happens in all cylinders for me.
Old 03-05-2013, 08:57 AM
pjinca pjinca is online now
USAF Pararescue Veteran
Mein Auto: 2008 550i
Could it maybe be as simple as condensation in the fuel tank? Perhaps replacing the fuel filter in the tank and/or some Stabil to reduce moisture in the fuel would help?
2008 550 - Carbon Black/Black - M-sport, Cold Weather, Premium, NAV, Comfort Access, Logic 7 (LOADED, every option except night vision) - mods done: RPI GT exhaust, RPI scoop, K&N filter, 20" wheels. planned: ESS tune, CKS coilovers, CF Hamann style lip, RD Sport trunk spoiler, ESS SC kit, Magnaflow headers
Previous 3 cars (the 550 is my 38th car):
2005 530i - Prem, Sport, NAV
2006 Jeep SRT-8
2003 Infiniti G35 coupe
Old 03-05-2013, 09:14 AM
Fuel filter is something I should try. At 188K miles, I'm not sure if it's ever been changed to be honest
I've ran a couple bottles of Techron through. I didn't notice any real change
Old 03-05-2013, 09:17 AM
I know of several E60 drivers (V8 and I6) who changed their fuel filters before 100k miles and they were disgusting (the filters not the owners ). It is worth a shot.
2006 Jeep SRT-8
Old 03-05-2013, 09:32 AM
Here is a DIY and it shows how bad the Fuel Filter was after 125k miles - http://forums.5series.net/diy-do-you...t-swap-121415/
2006 Jeep SRT-8
Old 03-05-2013, 09:47 AM
awesome, thanks!
Old 03-05-2013, 09:56 AM
Holy crap those things are dirty!!!
I'm definitely going to change mine out soon. I'm sure it needs it regardless
Old 03-05-2013, 09:57 AM
LOL, yeah, they get pretty nasty and it's in an area most people would never think to change it.
2006 Jeep SRT-8
Old 03-05-2013, 01:01 PM
Potentially dumb question:
RealOEM has a left and right fuel level sensor / filter. Do I need both or just one?
16146765820 - http://www.realoem.com/bmw/showparts...53&hg=16&fg=15
16146765826 - http://www.realoem.com/bmw/showparts...54&hg=16&fg=15
edit: NEVERMIND, I see only the second one (16146765826) has an actual filter listed in the part number, so I assume this is the only one I need. If this is incorrect someone please feel free to let me know!
Old 03-05-2013, 01:15 PM
Good question, I am not sure, maybe better to replace both? Also, there is a carbon filter for the gas tank that apparently gets dirty and needs attention when you live in an area with extreme weather changes (luckily we don't really have seasons, per se, in SoCal):
http://forums.5series.net/e60-m5-dis...-128133/page9/
2006 Jeep SRT-8
Old 03-05-2013, 01:54 PM
I think one is just a level sensor, then the other has the actual filter
I'll have to do some reading on charcoal
Old 03-05-2013, 02:45 PM
bmwoem1 bmwoem1 is online now
Regional Sponsor
Mein Auto: X3
Sounds like worn intermediate levers to me... But with the high mileage, I would do that filter first
Old 03-05-2013, 04:41 PM
I looked up changing the intermediate levers earlier in ISTA/D.. That one looks like a fun one, lol. How hard is it to actually do and what kind of special tools are actually needed? I know BMW would label a crow bar a "special tool" with a $500 price tag if they could get away with it (hell, they probably DO do that)
I think that's probably what it is too though.
Any thoughts on why it only does it in colder weather? It's starting to warm up here and was over 40*F this morning and it ran pretty good. Still not perfect, but I think once it gets up to 50*F it will smooth out
Old 03-05-2013, 04:48 PM
Hogie's Avatar
Hogie Hogie is offline
It's 5 O'clock Somwhere
Mein Auto: 330i, Z3 2.8L, 545i
When I purchased my CPO 04 545i I had two issues resolved by DME updated SW by the dealer.
1. Car would jerk at slow speeds, like in a parking lot. Felt like having a manual in 1st gear and pushing the gas pedal.
2. Rough start and idle for first minute or so, car would chug at times.
The dealer did inspect the levers as I was very close to the affected build date but they found no issue there. They opened a PUMA case then updated DME SW. The two issues never returned after that.
Old 03-05-2013, 04:53 PM
May be worth trying that as well since I need to update the transmission computer anyways. I'm not sure what version I'm on. I thought I was at V36 but not so sure any more after doing some more looking around in INPA
Old 03-05-2013, 05:03 PM
Also, looks like it's about $700 just for the intermediate levers if I replace them all. Lovely.
Old 03-05-2013, 05:56 PM
Found this very long thread that deals extensively with this issue
http://www.xoutpost.com/bmw-sav-foru...ssue-06-a.html
