Old 06-10-2009, 03:28 AM
SydneyZ3 SydneyZ3 is offline
Mein Auto: BMW Z3 1.9L (1997)
Question What do I really need to fix on my crumbling Z3
Hi guys,
Had my Z3 in for some tests and they say it needs the following repairs. Which do you think definately need to be done. I'm short on cash and could do without spending ANY money!
- Cam-shaft sensor (I've been living with this prob for two years - it only causes the engine to drop out once a month on ave)
- engine O2 sensor
- Seat Belt pre-tensioner (is causing the airbag light to come on)
Would appreciate your sage advice!
- Craig
Old 06-10-2009, 05:30 AM
Doc Holliday Doc Holliday is offline
Still Cruisin'
Mein Auto: 2003 325xi, 2001 Z3 3.0
Originally Posted by SydneyZ3 View Post
Hi guys,
- engine O2 sensor
- Craig
The first two are more important than the third, as long as you don't care about the airbag light.
If you can work on the car yourself, none of these are overly complicated fixes.
Old 06-10-2009, 06:01 AM
Monolith Monolith is offline
Mein Auto: 1997 Z3 1.9L DASC Auto
DIY link for the cam shaft sensor:
http://bimmer.roadfly.com/bmw/forums...4057304&page=1
Old 06-10-2009, 04:36 PM
Originally Posted by Monolith View Post
Thanks Monolith - I'm totally hopeless with anything more than hammering a nail into a wall so I think I'll leave this one to the experts!! It's a pity the parts are so expensive - that's what blows the cost out.
Old 06-10-2009, 04:37 PM
Thanks Doc - I probably should have added that I may sell the car in the next few months and the airbag light is definately something that people will question, so it sounds like I have to get everything fixed...arrgghh.
Old 06-10-2009, 04:50 PM
cngizbleevng's Avatar
cngizbleevng cngizbleevng is offline
hardtop potentate
Mein Auto: 2002 Z3 3.0i 5 speed
I just replace both camshaft sensors this evening. Not too bad a job (about 1.5 hours tops), and I got both sensors from Kragen for $160. If you have a Bentley manual it helps explain things.
Old 06-10-2009, 10:04 PM
SDrege SDrege is offline
Mein Auto: 2008 Z4M, 2004 R1150RT
Regarding: Seat Belt pre-tensioner (is causing the airbag light to come on)
Does this not mean that the airbag is disabled?
I had the seatbelt assembly replaced on my 2000 Z3 (2.3) because of this.
Comments, out there?
Old 06-11-2009, 09:17 AM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
Umm, this is a DIY and put half a day in on a Saturday and you should be able to fix all of these things for not much money compared to the stealership.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 01-23-2013, 12:26 AM
The airbag light was due to high tension on the wire caused by moisture from leaking soft top. It actually had nothing to do with the pretensioner. They cleaned up the wire and it was ok but unfortunately got more water in through the roof and its now back again.
Old 01-23-2013, 06:23 AM
vintage42's Avatar
vintage42 vintage42 is online now
BMW CCA 1405
Here's another DIY on that...
http://forums.bimmerforums.com/forum...8&postcount=31
camshaft, engine, seatbelt, sensor
