E34 (1989 - 1995)
Old 01-23-2013, 08:06 AM
windgat windgat is offline
Mein Auto: bmw 525i e34
540i misfire and start prob
bmw 540i e34 takes forever to start and when started there is a misfire
fixed a cracked manifold.replaced fuel pump but still no results if someone knows what the problem is help
Old 01-23-2013, 08:45 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is online now
Humble E34 lover
Mein Auto: 1992 525i
Check the crankshaft position sensor. Should be 540 +/- 10% ohms. Check main relay. Check fuel pump fuse and fuel pump relay. Check fuel pump.
Get the Bentley manual and read, read, read.
Good luck.
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-23-2013, 09:07 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
i would check spark before fuel. seems like a bad coil or plug even...
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
Old 01-23-2013, 07:33 PM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: 535i
I would be inclined to check plugs and coils. I suspect coils can be tested and the Bentley manual, already reccomended, should have the specs.
When you replaced the fuel pump did you verify fuel pressure? Can you hear the pump run? If no pressure follow the relay advice from BMRLVR.
Check for other vacuum leaks, cracked hoses, fittings.
Winter Rules
Old 01-24-2013, 02:04 AM
thats the thing.8 bosch spark plugs was put in.as for coils there was one dead so i replaced.fuse,relay that was the first thing i checked.as for the sensor where to get new one remember south africa
Old 01-24-2013, 11:00 AM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
Buy a parts car.
Old 01-24-2013, 11:44 AM
SwissCheeseHead SwissCheeseHead is offline
Mein Auto: 08 G37,94 530i,11 328iT
I would go with others and check for spark. If it's not spark plugs or coils and you replaced fuel pump, I would check for fuel pressure. Lastly, check for compression between 142-159 psi. Are you throwing a code? I'm still new to OBDI but it might point you in the right direction at least.
2008 Infiniti G37, 1994 BMW 530i, 2011 BMW 328iT
