Old 01-21-2017, 03:01 PM
yogi799 yogi799 is offline
Mein Auto: '11 535i, '99 328i retd
Oil filter housing gasket replacement DIY VIDEO (535i N55 3.0)
Here is the video, hope this helps someone doing the job next.
I have done many repairs and this one was a nightmare. Mostly, as some members on here said, due to extreme lack of space. Basically, the whole repair is hinged on removing parts just to gain access to a couple bolts (terrible design... was there really no other way?).
Either way, there are two gaskets and one can be done in as little as 30 minutes while the other... well, here is where the nightmare begins. I was under the impression, from everything that I've read, that the back bolt under the intake manifold was the problem. Turned out, in my case, that the very front lower bolt was MUCH MUCH worse. The one under the intake is easy to take out if you simply invest 30-60 minutes working your way to it (just time, little stress). The front lower one is seemingly easy but this can be misleading... I've found it incredibly hard to access. It included me running to the store picking up an emergency E torx wrench set (I only had sockets) and I spent probably about 2-3 hours alone on removing and reinstalling that one darn bolt.
*** DO NOT DROP ANYTHING *** into the engine bay or you're screwed. I learned from the advice of the others and did not drop any intake manifold bolts and nuts. Good, I thought, until... 2 hours later I dropped the E12 socket. Boy was I pissed off at myself. I spent 2 hours jacking up the car in my tight garage, diving underneath the messy car (coolant leak from removing the housing), removing the bottom shield (10 screws at least), nearly cutting my fingers on reinstall of it only to realize my socket was NOT there. This was plain terrifying... it would have me unable to finish the job, not to mention having to go buy another $40 set of E-torx. Finally, when I continued to work blind by sticking my fingers into everything including the fan shroud, a miracle happened: I felt the socket sitting next to one fan blade. Can you believe how loud I yelled when I found it? That was 6 hours into the job, 1.5 hours into looking for the socket alone... just a terrible experience overall. I have done some nasty repairs before, including suspensions, stiff and stubborn cooling systems, CVVs on my old E46.... but this one seriously kicked my butt.
Mind you the 2nd time around things would go much more smoothly. Probably 3 hours total... First time it took me 10.
Someone just said a CA dealer quoted $1000 for this job.. boy that made me feel better. Probably $800 in labour alone so I did save a few pennies... or I hope so at least...
That said... enjoy! LOL
2011 535i F10 delivered
1999 328i E46 retired
Old 01-21-2017, 03:30 PM
samadkins29's Avatar
samadkins29 samadkins29 is offline
bimmerfest Supporting Member
Mein Auto: 2011 535i
What symptoms were you getting that prompted this repair? Burning oil? or just standard wear and tear?
Old 01-21-2017, 04:20 PM
Flatland328's Avatar
Flatland328 Flatland328 is offline
Mein Auto: 2013 535i xDrive MSport
Thanks for posting this. I don't need it right now and hope I don't need it anytime soon, but I bookmarked it for a rainy (oily?) day. Sorry to hear that it took that much time. I'd guess I spent about 4 hours when I changed the same gasket on my 3 series but it was so darned annoying, my brain may not be letting me recall it accurately.
2013 535i XDrive
M Sport Package, Premium Package, Cold Weather Package
Rear View Camera, Comfort Seats, Ash Grain Wood Trim, Parking Distance Control
Navigation System, Premium Audio System
Other: 08 Silverado Crew Cab Z-71, 06 Mustang GT Convertible
Past: 328xi, Silverado, S-10 Blazer, Grand Prix (x2), Camaro, Accord and yes.......Chevrolet Vega!
Old 01-21-2017, 08:24 PM
Ric in Richmond Ric in Richmond is offline
Mein Auto: .
Good video thanks. I have 2 of these motors and likely adding a third so odds are I will be doing this one day
Sent from my SM-T530NU using Tapatalk
Ric in Richmond
'11 135i BSM/ Koral 6 mt
'11 528i
'02 Mini Cooper S
'90 325is M52 swap
'83 R80
Old 01-21-2017, 08:33 PM
You're welcome guys. I too got a lot of good info here and also found some resources on YouTube that got me started. However, no video about this for the N55 until mine, so I feel great being able to help others.
Good info in this thread, actually both. Includes pics of the symptoms. Good luck!
http://www.bimmerfest.com/forums/sho...d.php?t=956137
http://www.bimmerfest.com/forums/sho...d.php?t=856429
Old 04-10-2017, 03:51 AM
pennadam pennadam is offline
Mein Auto: 2012 535i
Took it in for routine oil change and the tech at the local Indy shop noticed Oil leak. Got a labor estimate for $660+(parts $151). Contemplating doing it myself - Thanks to Yogi's DIY video.
I'm disappointed that I have to do this at 40K miles! (2012 5353i)
Old 04-10-2017, 08:23 AM
Yeah, I hear you... Mine probably started around 50k. Or sooner but I did not notice until it was really bad.
But heads up... your setup looks different. Your heat exchanger and some additional lines look very different. I am guessing the worst bolts will be the same, but you have a couple other things to do.
Old 04-10-2017, 09:10 AM
HizEternal HizEternal is offline
Mein Auto: 535i Xdrive F10
Seeing as I have the same car but with xdrive, not sure if you said that but my engine bay is exactly the same, why didn't you remove the fan to get more space?
I plan on doing the idler pulley tensioner and belt later on and to do that, for more space to work, removing the fan would help.
Either way I thank you for your documentation. Makes it easier for the rest of us.
Old 04-10-2017, 01:00 PM
Good point... That was because I had no clue it would be that hard! The hardest bolt was supposed to be the one under the intake manifold!
You bet this time around I would remove the fan. Mind you that in itself will add extra time but I am sure I'll do this next time.
Old 04-14-2017, 05:50 PM
ngsir ngsir is offline
Mein Auto: 2014 F10 520d
wrong reply
Old 04-14-2017, 05:59 PM
visualguy visualguy is offline
Mein Auto: CA
Not designed to last + not designed to be worked on = lease only
Old 04-14-2017, 06:20 PM
LOL. Someone has just posted on Youtube that it cost them $860 to replace those two damn gaskets.
Insanity! Given the parts are only about $80... that is a whole lot of dough for labor. Seriously... BMW couldn't have tilted the housing 10 degrees to the front to make the gasket replacement easy?
Old 04-15-2017, 08:01 AM
ejrobert ejrobert is offline
2014 F10 535d
Mein Auto: 2014 535d MSport
OF course they couldn't! If they had, everyone would DIY it!
gasket, housing, leak, oil, replacement
