Fog lamps - Bimmerfest - BMW Forums
Old 01-26-2013, 06:52 PM
johninjax johninjax is offline
Mein Auto: 2014 X128i
Fog lamps
Is there any way to turn off the fog lamps if you're using the DRL's? I can't find anything in the manual. Any ideas?
Old 01-26-2013, 07:10 PM
gfeiner's Avatar
gfeiner gfeiner is offline
Mein Auto: 2012 X3 xDrive35i
My fog lamps dont turn on just because i have drl on. The fogs dont turn on unless i press the foglight button. The manual does say that if u turn the fog lights on, then the drl will turn on too. But u can run drl without fogs.
Old 01-26-2013, 08:08 PM
Fogs are on, if I press the fog button nothing changes.
Old 01-27-2013, 05:41 AM
Doug in NC Doug in NC is offline
Mein Auto: 2011 x3 28i
That's not normal. I have DRL on but the fog lights don't light up unles I use the blinker or turn them on with the fog light switch.
Old 01-27-2013, 06:01 AM
02420X3 02420X3 is offline
Mein Auto: 2011 X3 35i
Same here.
Old 01-27-2013, 06:45 AM
Norman38 Norman38 is offline
Mein Auto: 2013 X3 2.8
I have to press the fog lamp button. They don't automatically come on.
Old 01-27-2013, 08:40 AM
The X Men The X Men is offline
Mein Auto: 2013 X3 35i
The X3 use the fog light as a blinker?
Old 01-27-2013, 09:08 AM
SpaceManGray SpaceManGray is offline
No, the blinker is separate... however the fog light below the blinker comes on with the blinker to act as a cornering light (for better visibility of curbs, etc). Or at least that's the intention, I don't know that it makes much difference. If you turn the wheel without the signal, the fog light in that direction also comes on. Also, both fog lights come on when you're in reverse for the same reason.
2011 X3 (F25) xDrive 35i 3.0L, nav, xm
Old 01-27-2013, 09:10 AM
wavewuver wavewuver is offline
Mein Auto: 2011 X3
I run my DRL all the time and the fogs are off, unless I turn them on.
I only recently realized that the left or right fogs come on individually when you are making a turn or you are signaling to turn. Again, it's only one fog light at a time. Had the car for almost two years before I noticed that.
