Old 01-22-2013, 04:20 PM
Silver2010 Silver2010 is offline
Mein Auto: 2010. 750lix
Alignment question .
Hi all
Brought my car in to Rallye BMW today ,noticed front right tire rubbing slightly on inside of fender
Before dropping it off i measured the distance from top of tire to fender
Driver side 3 1/2"
Passenger 2 1/2" told SA this morning
Sa called and said inside fender/ mud guards out of alignment that's why it's hitting ,need to remove bumper ,going to be at least two hours labor and then see what other parts needed,would not be covered under warranty wtf?
Then I said no one has ever removed this before .????
Then he says what about the alignment ,we could do that for 325!
So had new tires put on two weeks ago
Did get a price from Rallye but at 3,100 decided to go House of tires instead .
So is it possible that the alignment could change the distance from the top of tire to fender ?
Old 01-22-2013, 04:28 PM
dbs600 dbs600 is offline
Mein Auto: 2011 750LXi Individual
Who's your service advisor?
I'd get a second opinion.
Old 01-23-2013, 11:56 AM
Individual750LI's Avatar
Individual750LI Individual750LI is offline
BMW rocks!
Mein Auto: 2013 750I M
They only charge you 325 for an alignment? Last time they charged me 389.99. Now I had new tires put on, and I need alignment again, I can't believe the alignment would get messed up just by changing 4 tires.
2015 X6M, 2014 X1, 2015 Kia Sedona SX-Limited
Old 01-23-2013, 12:43 PM
Alignments are recommended after new tires, but shouldn't be compulsory for the car to track straight (with new tires). Probably most needed if there was an alignment problem previously, where the old tires didn't wear evenly.
Old 01-23-2013, 06:29 PM
Total waste of time at dealer ,I guess they are used to people not paying attention,I'm at a loss ,
Seems once SA realized I wasn't buying that an alignment would change height of tire to underside of fender
I got the cold shoulder !
Well I need the loaner back.
Twenty years ago .... Would have said take your piece of ........ Back , oh and go ....
Calmly returned loaner, nothing said
, nothing
Like receiving a bad meal and the server knows it
Now I have to try and find a place that's gonna be straight with me or someone can recommend a honest place?
Or take the dust of the tools and pull it apart myself
What a shame ,would have been so convenient , dealer literally two miles from the house
Old 01-23-2013, 07:47 PM
Sorry to hear this; Rallye has let me down too, as mentioned.
Give Hassel a shot, but be sure to look your car up and down before dropping it off!
Old 01-24-2013, 07:26 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
checking ride height is part of every ksd2 alignment if ride height is not correct alignment can't be performed than technician will replace your leaking air strut under warranty
Sent from my Nexus 7 using Bimmer App
Old 01-25-2013, 01:46 AM
M&b Tek,
So ride height needs to be correct prior to alignment?
After strut install I assume alignment is needed?
Would this also be a warranty item as well then?
Thank you
