BMW Coding and Programming
Discuss coding options and features on your BMW here. |
New Code: Adjust the Sensitivity of the Automatic Headlights
Many of you have complained that the Automatic Headlamp Control seems too sensitive. Many times my headlights are on as late as 9 or 10 AM, even when the sky is bright a clear.
You can adjust the sensitivity of the control by changing a few codes. This process can be a bit complex (there seems to be other controls in place) so I suggest the following changes: JBBF->3530 RLS, 0C->RLS_DEF_FLC_SCHWELLWERT_SATZ-> unempfindlich (default is empfindlich) JBBF->3530 RLS, 0C->RLS_FLC_SCHWELLWERT_SATZ unempfindlich (default is empfindlich) Just this. Not not mess with the wertes. After many tries, it seems that the default for "non-sensitive" (unempfindlich; werte=01) works for me (ignore the Japan/China comment in the setting). The default setting for North America (and perhaps other locations) is "sensitive" (empfindlich) or werte=07, which seems to fast in turning the lights, even in fairly bright conditions. The "normal" setting is still a bit too fast (in my opinion) turning the headlights on. The settings range from (with the default werte value next to it): non-sensitive (01), normal (03), sensitive (07) and very sensitive (0B or 11 in decimal). The wertes range from 0 to 15 (0F). That said, adjusting the wertes is not a straight forward affair. For example 00 does not seem to make it less sensitive than 01 (at least in my hands). The suggested setting works for me, but others can tested by you. Please report successful changes so we can all learn more about these settings. Notes- 1) It seems this change sometimes is instantaneous but in other occasions it takes a bit of time to "set". Give it at least a day after the code change to assess its effect. 2) The sensor normally takes about a minute or two to respond to a change in brightness. 3) When you are indoors (a garage or a tunnel for example), the lights always come on regardless of brightness. This is controlled by another independent setting not affected by this change. JEG23
2011 550i Space Gray /Black Nappa, Dark Wood ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR Last edited by JEG23; 01-24-2013 at 08:42 AM. |
Awesome find. Cool
![]() Coding Inquiry call 917-939-4980
I found these long ago, but changes make no change, no difference between each "werte".
awesome, i'll try these tonight
That is not the case. There is a dramatic difference between the default (sensitive) and non-sensitive (unempfindlich). The specific werte changes are complex as I mentioned. That is why I recommend just the changes above. Try it and you will see. JEG23
2011 550i Space Gray /Black Nappa, Dark Wood ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR Last edited by JEG23; 01-24-2013 at 08:40 AM. |
Thanks ![]() JEG23
2011 550i Space Gray /Black Nappa, Dark Wood ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR |
canadian 01/2011 535ix
The default werte values I have are different and still finding them too sensitive: JBBF->3530 RLS, 0C->RLS_DEF_FLC_SCHWELLWERT_SATZ-> empfindlich/werte=02 JBBF->3530 RLS, 0C->RLS_FLC_SCHWELLWERT_SATZ -> empfindlich/werte=02 Choices for both are: normal/werte=01 empfindlich/werte=02 unempfindlich/werte=03 sehr_empfindlich/werte=04 I'll try unempfindlich/werte=03 and see how it goes before changing its werte to 01
Regards, Alex 2012 w204 Mercedes-Benz C350 4MATIC MY 05/2012 Black/Sahara 2011 F10 535i xDrive MY 01/2011 Sophisto Grey/Black |
As I mentioned, the werte values are complex. Just change from empfindlich to unempfindlich and do not mess with the werte values for now. That alone will have a dramatic impact on the sensitivity of the headlight control. I have experimented with this for weeks. If you change in RLS_DEF_FLC_SCHWELLWERT_SATZ or RLS_FLC_SCHWELLWERT_SATZ the setting and also the werte, you defeat the setting. The wertes are defined by other settings below those. I did not want to make this over complicated and confuse everybody. As I said just change: JBBF->3530 RLS, 0C->RLS_DEF_FLC_SCHWELLWERT_SATZ-> unempfindlich (default is empfindlich) JBBF->3530 RLS, 0C->RLS_FLC_SCHWELLWERT_SATZ unempfindlich (default is empfindlich) and see if you are satisfied. I think you will. JEG23
That is why I was surprised by your initial response. As I mentioned I have experimented with these for weeks. Changing to non-sensitive (unempfindlich) makes a world of difference. JEG23
Can't wait until my car gets out of service to try this. Having headlights on in the middle of a bright Southern California day is superfluous.
Thanks for finding this! |
Do not set the werte just set to unempfindlich. JEG23
Jeg i think you deserve a PHD in Coding
DreamCar,
That is nice of you. How many bananas before I get the PhD? ![]() JEG23
you can ask Sean to write a recomendation letter for you. Jokes aside thanks for all your new findings. |
He is pretty stingy with the Bananas ![]() It is fun to find new functions, but my car is going to explode at some point. I am testing so many things at the same time, that every time I hit a pothole, I think my car finally felt apart. JEG23
2011 550i Space Gray /Black Nappa, Dark Wood ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR Last edited by JEG23; 01-25-2013 at 08:38 AM. |
I really envy you, i wish i had my car
Yes, that's what I did.
I may meet up with Shawn next week if he finds the time. I'll get him drunk and make him confess on a hidden camera that you get the bananas
![]() Day O, day O Daylight come and me wan' go home Day, me say day, me say day, me say day Me say day, me say day O Daylight come and me wan' go home Work all night on a drink of rum (Daylight come and me wan' go home) Stack banana till the mornin' come (Daylight come and me wan' go home) Come, Mister Tally Man, tally me banana (Daylight come and me wan' go home) Come, Mister Tally Man, tally me banana (Daylight come and me wan' go home) Lift six foot, seven foot, eight foot bunch (Daylight come and me wan' go home) Six foot, seven foot, eight foot bunch (Daylight come and me wan' go home)
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
You may have exeeded the authorized
post limit! I am going to consult the forum user manual and decide how to proceed from here . Being out of the country does not allow you to break the rules! That's not how we do things in the BMW Coding and Programming forum I'm also not sure singing is authorized either. Thanks to JEG23 I've been testing this for a while. Changing the "werte" selections definitely changes the sensors behavior. Sean Last edited by ImSW1; 01-26-2013 at 10:20 PM. |
#25
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
