E36 (1991 - 1999)
Old 01-23-2013, 05:04 PM
jntramey jntramey is offline
Mein Auto: ML320
Swapping rims between BMW series...
Hello all, first time poster but long time stalker.
I had a 97 BMW 528i for about 2 weeks before selling it out of necessity to our oldest son who was away at college (his Porsche 944 just wasn't reliable anymore.) He has now replaced it with an '08 535. He gave the 528 to his sister who is also away at college. The head gasket gave up the ghost and we purchased a sweet little '95 318 4 dr for her which she LOVES.
My daughter wants the rims off the 528 put on her 318. Aside from requiring smaller tires, the 528 rims appear to be a decent fit however, when attempting to put the 318 rims on the broken 528 (to keep it off blocks) the hub is slightly too large for the 318 rims to fit over.
Examining the 528 rim mounted on the 318, I can see about a 1/16" gap all the way around the hub meaning the rim is supported by the 5 bolts and the hub only providing basic centering services while installing the lugs.
My daughter is a bit of a "granny" when it comes to driving style so I'm not concerned about "spirited driving" in the least.
Is there a risk I'm not aware of concerning the strength of the BMW lug bolts being the sole support of the rim?
Old 01-23-2013, 05:13 PM
LOW36's Avatar
LOW36 LOW36 is offline
Lowlife
Mein Auto: Bagged E36 328I
They will fit fine on the 3 series but I recommend getting some hub-centric rings so they fit properly and lock the wheels in the center of the hub. This will also help with vibrations while driving, fuel economy, tire wear, etc.
Its worth it to spend $10 on the hub-centric rings though.
***Bagged E36 ***
FACEBOOK
Old 01-23-2013, 05:16 PM
Mein Auto: ML320
Can you recommend a source for the hub centric rings? The last set I purchased were locally machined.
Old 01-23-2013, 05:20 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
You will have vibration as the wheels do not self center on the lugs alone, they need the hub flange to center.
The 5 is the odd BMW out, it has a 74.1mm hub while most everything else is a 72.6. You'll need 1.5mm hubcentric rings.
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 01-24-2013, 10:25 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
You think that's bad. The X6 apparently has different hub sizes per AXLE.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 01-24-2013, 11:27 AM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
These will work. With some searching you can find other metal rings for a bit less. You can get molded plastic for around $10.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 01-24-2013, 12:10 PM
ECSTuning's Avatar
Instructor of the Stig™
The rings found HERE will make the E39 rims hub centric with her E36.
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
Old 01-24-2013, 12:17 PM
I Am The Machine
Stfu. Just even you think the X6 can't get any worse.....
Wild. It does indeed use different hub bores.
// Chad //
You're a derbanana
