Old 01-23-2013, 06:23 PM
FinishLine FinishLine is offline
Mein Auto: 745LI
Next to No Heat in the Cabin...Causes?
So last week I noticed that my cabin is not getting as warm as it used to, and if you feel the air coming out was luke warm at best and felt "cool" and this is after an hour drive. So I googled the thermostat (just read there is 2?) and came across a thread about removing the air from the system so I did that and although better, still not great. Now that its -30 degrees out, I can really tell its not working well. My coolant was nearly topped off so I do not believe it to be leaking anywhere, no spots under car either, just looking for some things I can check to see if they need replacing as the nearest dealer is 90mi away and I don't really have time to get there soon.
Commercial content removed. Please email admins for sponsorship information.
**Installed World's First ipad3 in a C6 Corvette**
Old 01-23-2013, 07:24 PM
Mein Auto: 745LI
Hopefully the good news here is I have the receipt from the previous owner that the coolant pipe HAS BEEN replaced last May, so hopefully this will be something else.
Old 01-23-2013, 07:43 PM
jkess114 jkess114 is offline
Mein Auto: Motorcycle
Go into the climate portion of Idrive (push center console knob to left.) Between the arrowed vents for choosing where you want the air to come from, click on the temperature slider and slide the left and right all the way to the left (red). Next, make sure that the arrows are at least selected for the front vents. If you want heat on your feet, select those arrows...
Old 01-23-2013, 08:00 PM
Mein Auto: 745LI
already did.
Old 01-24-2013, 04:58 AM
Ultimate745i Ultimate745i is offline
Ultimate745i
Mein Auto: 2004 745i
Dont know if this will help, but back in the summer I had more heat than a/c coming out of my vents and this is what I had to get replaced:
http://www.partsgeek.com/catalog/200...ter_valve.html
From my understanding, it can work for the opposite issue that you may be having. Hope this helps.
Fun Doesnt Come Cheap!
Old 01-24-2013, 07:45 AM
First_745Li's Avatar
First_745Li First_745Li is online now
Mein Auto: 2003 745Li
I noticed that same issue a while back. After checking the vent controls, fluid levels, I decided to change my thermostat bc of a thermostatic fault error and it solved my heating problem.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 01-25-2013, 07:27 AM
rideme2's Avatar
rideme2 rideme2 is offline
rideme2
Mein Auto: 2006li bmw
There is a AUX pump for the heat.
2006 750li K&N Filters Giovanna Kilis on 265/30/22 305/25/22 HID fogs 6000k Mtec angel eyes all lights 6000k ACS front lip,ACS rear wing,ACS rear window wing.dual exhaust working qual tips, rear camera, upgrade DVD to front watch jl13.5t sub with jl500/1v2 amp power cap.PassPort 9500ci,CrossDrilled&Slotted Rotors with EBC Brake Pads.Rear comfort seats, Fully loaded from dealer. Next mod iPhone hookup, .
