E46 (1999 - 2006)
Old 01-26-2013, 12:23 PM
lgr122 lgr122 is online now
Mein Auto: '00 e46 M43, '05 e87 M47
Question Unstable idle.
What do you guys think would be most probable reason for unstable idle?
Happens only once in a while and doesn't seem to cause anything else (yet?).
Idle can be wondering between 1000 and 500rpm. It happens only once in a while, but i feel like it's coming more often nowadays.
According manual 850rpm is normal for this engine.
It has been -10C (14F) or colder for long while, but i do visit underground shopping mall parking quite regularly for melting some ice and snow off.
Old 01-26-2013, 12:41 PM
sjbmw328i sjbmw328i is offline
Mein Auto: 2000 BMW 328i
maybe check your idle control valve and see if its clogged up and needs cleaning, but i might be wrong.
CHECK OUT MY DIY FOR AMBIENT TEMP SENSOR (EBAY SENSOR) -40F/+122F PROBLEM FIX
http://www.bimmerfest.com/forums/sho...d.php?t=672225
Old 01-26-2013, 12:47 PM
I think that might be some possible cause according search on earlier threads, but still wondering if there can be also some other good ideas.
Old 01-26-2013, 01:24 PM
whinojosa's Avatar
whinojosa whinojosa is offline
Mein Auto: 325i W/O CDV
Check the DISA. Relatively easy to inspect. Make sure there is at least light resistance to the plastic flap while turning.
I had a rough erratic idle (between 700 - 1100 rpm) at about 110-115k miles on the clock. DISA was completely broken. Replaced (purchased at local dealer for $250) & it fixed the issue. Not sure if you mentioned you had any codes - but mine threw p0174 and 171(? Not completely sure) Both indicated air issues.
- Will
Los Angeles BMWCCA Member#415991
Old 01-26-2013, 01:28 PM
Since you brought up that, here is a old DIY video from way back of how to to take out/clean/ and install the Idle control Valve. http://www.bimmerfest.com/forums/sho...d.php?t=496398 During the video, it also shows what the DISA looks like and how to take it out. Maybe check with those first, and if problem still occurs. Hopefully another fester will be willing to help on this thread.
Old 01-26-2013, 01:32 PM
Hmm... i'll check those...
still about couple weeks before it's time to oil change, probably going to be ok till then.
Old 01-26-2013, 01:45 PM
rgk330i's Avatar
rgk330i rgk330i is offline
Mein Auto: 2013 335i M-Sport
Fixing a vacuum leak (or two, or three) and replacing the VANOS seals seemed to solve this problem once and for all on my car. I've had recurring vacuum leaks since without such a bad fluctuation in the idle speed, so I think the VANOS might have been the key.
2013 335i M-Sport, ED May 2013
Old 01-26-2013, 01:49 PM
I wouldn't be surprised if some hose is bit fractured also, freezing weathers can be bit nasty on those. Anyway, it's not like some problem quite yet, but i'm trying to see symptoms before it become problem.
Old 01-26-2013, 04:28 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
I am not familiar with those engines in the cars like yours, however bad VANOS seals cause poor idle in the M52tu motors we run in over here. Might be your issue.
