E46 (1999 - 2006)
Old 01-19-2013, 03:23 PM
KyleEvolv KyleEvolv is offline
Mein Auto: Silver 1999 323i
99 323i Fuel leak
Hey guys I haven't been able to get onto the fourm as much as I would like but I have a safety issue going on. Underneath my rear driver side seat there is fuel pooling under the metal plate that is held down by four screws. I only noticed this because I filled up my fuel tank completely and now fuel is leaking from there to the ground. I'll try to get a picture up quickly.
Thank you
Old 01-19-2013, 04:04 PM
I've noticed that the part that is leaking is the line that sends fuel to the other pump. I don't know what exactly this is called or the part number. Though I assume that a new one (line) can be fished though to the other side and installed quite easily. Does anyone have any idea?
Thank you
Old 01-19-2013, 04:19 PM
stevenj's Avatar
stevenj stevenj is offline
DIY Enthusiast
Mein Auto: 1999 323i ZSP
I have the same car as you, but I don't even know what you are taking a picture of (orientation wise)
But I would assume if you have a leaking fuel line it would be a no brainer to fix it asap.
Check out this site for parts info. http://realoem.com/bmw/partgrp.do?mo...3&mospid=47718
GL
If you keep on doing what you've always done
You'll keep on being what you've always been
NOTHING changes unless you make it change
Old 01-19-2013, 04:33 PM
GL
Yeah I was looking at some RealOEM diagrams, I know where it's leaking from but the diagram is just absurdly unclear as to what part it is. I assume that it's the fuel return line that's leaking (the line that goes from the jet pump to the electric pump) but I can't be sure.
In the picture above it looks like it's leaking from the black fuel line but I have no idea what BMW calls it...
Just fyi: the picture is of the top of the jet fuel pump on the driver's side of the vehicle.
Thank you for your input
Old 01-23-2013, 07:31 AM
Ha well... That was interesting. I've never had that happen on a forum before. Anyway I needed to replace the fuel line that was going from the secondary pump to the primary one. So if anyone is having this fuel issue, and I hope it's rare, that could be one of the few solutions. You may need to replace the secondary pump.
Old 01-24-2013, 07:00 AM
Mein Auto: '04 330Ci 6-speed
There is no secondary pump. The driver's side unit is a fuel level sender only.
It does intergrate with the sucking jet pump which is a purely passive device. The only part in the sucking jet pump that can easily fail is the check valve. That is so rare that I have never seen it on a forum. My BMW dealer said he has seen it tho.
