E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
E46 vs E83 cold start. And the winner is...
At about -10 degrees this morning, my wife's x3 had a rough time starting this morning, she cranked it for 5-10 seconds 3 times before it finally fired! Slllooowww cranks, too, and the battery was new in June. My trusty wagon fired right up like it was 65 degrees. Except that it didn't reach normal operating temp for over 20 min. But I am NOT impressed with the cold starting performance of the x3!
I haven't had any issues with cold starts, granted its not -10*F like you
![]() #465420 National Capital Chapter My Progress Thread 2000 323Ci | TiAg | Gray | AFE | UUC | Eisenmann | Koni | ACS Type III | Coby Wheel | 2006 X3 3.0i M-Sport | Silver Grey | Terracotta | Navigation | Premium Pkg | Cold Weather Pkg | AFE | |
Glad to hear it works. It seems that the X3 fuel lines/pump/regulator or something isn't so robust. It needs time to prime.
We'll try that tomorrow morning. Though it seems like the fuel system should have been primed plenty by the 2 or 3 attempts at starting it before it did finally fire. This car has cranked relatively slowly with ANY cold weather, the cranking speed is directly correlated to the temperature. The e46 might crank a LITTLE slower but nothing like the x3. I've read a few of the cold start issue threads but for one, but as long as it starts I'm not going to get too worried.
Check out the E83 section for cold start issues, and possible solutions.
In extremely cold weather, having a (heated) "battery blanket" and a heated oil dipstick are about the only thing that will make a real difference.
This is one area where AGM batteries have an advantage.
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
As far as battery heat, I suppose a trickle charger would also help keep the battery warm. While there isn't an issue with the charge on the battery, it would serve the purpose of keeping it a little warm, right? |
What kind batteries do they have?
Maybe your e46 just have more spare capacity and e83 is designed tighter to the limit? Generally increasing battery capacity can help any car in cold start, but some kind heating device can be even better. |
In Russia I saw one old man who was taking his battery inside his apartment every night and then bringing it back in the morning. Maybe bit extra trouble that way also, but i'm sure he didn't have too big problems about starting his old car.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
