E34 (1989 - 1995)
Old 01-24-2013, 05:46 AM
zfxpE34 zfxpE34 is offline
Mein Auto: 1995 BMW 540i E34
Here I am again.
After further news everything is going great, except..
I do not have any door ajar messages or any chimes, this concerns me..
Any advice on finding out why?
Old 01-24-2013, 06:06 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
lol, i have this too. My chime only dings when the door isnt closed and the key is turned to accessories
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
Old 01-26-2013, 04:01 AM
BMWFatherFigure's Avatar
Old School
Dare I say it? Grounds.
Current:
Previous:
Old 01-26-2013, 07:54 AM
Monsignor's Avatar
I'm not entirety sure what this whole thing you have with grounds is...
Sent from Joe's Galaxy SIII via BimmerApp
2006 325i/6 48k mi
Garden State Euros
Old 01-26-2013, 12:47 PM
Microtesties Microtesties is offline
Unregistered User
Mein Auto: 1990 BMW 525i
Do E34s have a door ajar message/chime? Mine doesn't and I never thought anything of it. I only get "KEY IN IGNITION" if I open the door with the car off and the key in.
Year: 1990
Model: 525i
Transmission: 5 speed
Mileage: 250k
Old 01-26-2013, 01:06 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
grounding issues are quote common issues for E34s, E36 and E46 even more so. wierd as they are as passive as things come.
Old 01-26-2013, 04:13 PM
Old School
The volts lost through bad grounds cause all sorts of problems with the computers/electronic controlers throughout the BMW ranges. Fixing them often makes the problems go away. Grounds combined with corroded terminals seem to cause more problems than anything else that comes up in the forums.
Current:
Previous:
Old 01-26-2013, 04:15 PM
Monsignor's Avatar
I understand what a ground is. I know it well. FF's reaction or suggestion of it when its mentioned is what I mean. See other threads.
2006 325i/6 48k mi
Garden State Euros
Old 01-29-2013, 10:51 PM
Mein Auto: 1989 525i M20B25
8/88 build date and I have it for the drivers door.
Yours should too.
IIRC, you have to be moving pretty fast for it to work, something like 25 mph. "test only if traffic conditions permit"
Old 01-30-2013, 12:46 AM
Yours should too.
My E34 has it, but 89 E32
Old 01-30-2013, 06:20 PM
Ssuss34 Ssuss34 is offline
http://i1341.photobucket.
Mein Auto: '89 E34 535i
So i recently had a bit of water enter through the sunroof due to a blocked drain. All issues are fixed now although the only problem that remains is that My "door open" chime keeps ringing everytimr I stop in traffac and continue to drive. its so annoying, as you would imagine the interior lights stay on the entire time as the "computer" thinks there is an open door. So I have turned the interior lights off until I get it sorted. So if you think its the grounds, please tell me where to look and how to fix ??
Old 01-30-2013, 06:37 PM
Did you try what I told you?
Do this. Remove the B-pillar cover. Behind where the seatbelt runs, there is a crevice that you can reach up into to get to the wires that control the door jamb switch. Short them together and see if the problem goes away.
If the messages do go away, you know the problem is at the switch.
Old 01-30-2013, 08:09 PM
Well, now my auxillary water pump just went out, so now to get one of those.
