Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X3 F25 (2011 - current)
The latest X3 brings some added style and some new features to the BMW SUV family. Talk about the new F25 now!
Old 01-24-2013, 06:46 AM
Highmodulus Highmodulus is offline
S65 + DCT = Happiness
Mein Auto: 2011 M3 E90 Melbourne Red
Expected mileage from OEM runflats?
I need a reality check. I brought my 2011 X3 35i to the dealer because the driver side front tire's outside edge was wearing faster than the rest of the tire (and was not matched on the other 3 tires). My X3 only has 13500 miles on it- just regular driving. No track or anything exciting. I figured its probably an alignment issue or maybe camber or something like that. Easy fix. No problem- the vaunted BMW maintenance plan/warranty should cover that.
Well- no. Despite making an appointment the day before the service writers seemed surprised to see me. I also got it there at 7am, yet by 3pm no call or anything. When I called, they had not even looked at it. At 4:30, still no call- so I call for the shuttle to come get me. I figure I will get a call telling me the car is done. Nope. When I get there- it looks like the car is done.
When I finally get a service adviser- I find they basically did nothing to the car. The SA claims that the tires are getting worn out, and I should expect to replace all 4 within 5000 miles, and I should then pay for a 4 wheel alignment at the same time. Oh, and they want $1600 for 4 new Pirelli run flats.
Are you kidding me- less than a year and a half of normal driving and you will need 4 new tires. SA claims this is what they expect. I am dumbfounded. In 3 years of normal driving you will need to spend $3200 on rather low performance SUV run flat tires?
If this is the case, then the X3 is gone. What am I missing?
2011 BMW M3 Sedan Melbourne Red over Grey
2011 BMW X3 Xdrive 35(i)- sold
2005 BMW M3 Coupe Black/Black 6mt- sold
Old 01-24-2013, 12:19 PM
Ian Sanford Ian Sanford is offline
Mein Auto: BMW X3 MSport 3.0d
Am having all four tyres replaced next week at 20,000 miles - all down to 3mm. UK cost for Pirelli's £1320 for 4 supplied, fitted & balanced ($2085) so $1600 cheap!
Old 01-24-2013, 01:50 PM
ductman's Avatar
ductman ductman is offline
Mein Auto: 2011 X5 35D /2011 M37X
First issue:
1. Tires need to be rotated every 7500, BMW will not tell you this as this is not included in
their maintenance
2. Alignment needs to be set on the toe side at the minimum specs ( BMW has a very wide
range ) Excessive toe will kill your tires, Total toe should be around .005 or so
alignment does not need to be done at the dealer, specify what specs you are looking
for
3. Dealers are extremely higher priced than the Tire Rack, Do not believe that the tires
from other than the dealer are not " approved " BMW tires, Tires I purchased from
the Tire rack have the same BMW " Star " on the sides.
4. The majority of SA are total morons in regards to anything.
Former BMW"s
2003 3.0 X5 ( E53 )
2002 330 Xi ( E46 )
Old 01-24-2013, 02:41 PM
noka noka is offline
Mein Auto: 2013 x35i M-Sport
Originally Posted by ductman View Post
First issue:
their maintenance
for
I had to replace tires on my C300 at 22K mi because the rears were totally worn. Since they were staggered, I decided to do the fronts as well. Mind you, these were not RFT! I got Continental DWS Extreme which showed much better wear. I believe that manufacturers enjoy cost saving by have special "OEM" tires made to their specs (read: "low cost"). That's what I heard in the past but I hope I'm wrong. Also, I had a well-known tire dealer do an alignment. They totally messed up the handling. Brought it to my MB dealer and, although more expensive, they made it perfect. YMMV
2013 x35i (Space Gray, MSport, CW/CWII, DHP, Premium, Premium Sound, Technology, BMW-Apps)
Retired:'09 C300 4Matic, '09 GTI, '06 750i, '05 C55, '04 R32, '03 M5, '02 GTI, 01 M5, '00 M-Coupe, '00 540i/6, '99 M3 Coupe, '98 M3 Coupe, '96 328i, ..., '86 4000CS Quattro, ... too many to list
Old 01-24-2013, 03:26 PM
Coder Coder is offline
Mein Auto: 2011 X3 xDrive35i
Smile 2011 at 24,000 miles
I expect our 2011 35xi with 18 inch Pirelli P7 All Season tires will get us through this summer with no problem. Hoping for 30,000+. I rotated them once at around 17,000 miles, no obvious wear problems.
Dave @7500 feet on the plains in Colorado
2011 X3 35i - Blue Water Metallic
Old 01-24-2013, 03:56 PM
Want the Thrill Want the Thrill is offline
Mein Auto: 2011 X3 35i
Run flats typically do not wear like regular tires and need to be replaced much sooner. The sales manager at our dealer said if you can get 20,000-25,000 miles out of runflats you are doing good. I would switch out your tires to NON-runflats and carry a can of slime and an aircompressor in the back. I have 11,000 miles on my 2011 X3 and the tread is just about half way. When I take these off, I plan on putting regular tires and doing just that.
Old 01-24-2013, 06:21 PM
Fighterpilot Fighterpilot is offline
Mein Auto: 2009 535i
The OEM run flats that came with my former 09 535i were bald at 25K, the back set at least. The front pair were only about 1/2 gone. However, the tires could not be rotated front to back. The next pair I put on were Continental DWS (non run flats) and the back set on those were worn out at 25K as well. I'm guessing the inability to rotate front to back will kill off most sport performance tires.
On our new X3 28i all the times are the same size so I'm going to make it a point to rotate these front to back in the typical fashion even if not recommended by BMW. My expectation is that I may get 30K out of the set by doing so. Assuming some sort of damage doesn't do them in before that. Once the run flats are worn I plan on just replacing them with regular non run flat tires. A risk I know as there is no spare tire w/ this vehicle.
In garage - 2013 X3 x28i, Sport Activity, Convenience, Cold Weather I, and Premium Packages, Rear View Camera, Park Distance Control, Sat Radio, BMW Assist w/ Enhanced Bluetooth. Black Sapphire with Black Nevada seats.
Previous BMW's
2007 525i - Totaled -->http://www.bimmerfest.com/forums/sho...d.php?t=664410
2008 535i - Traded in
2009 535i - Totaled
Old 01-25-2013, 08:48 AM
Thumbs up
Thanks everyone- if I stick with the X3 I think I will go with the non-run flats from TireRack. Any recommendations for the X3 that you guys have had luck with?
Old 01-25-2013, 07:22 PM
fb88 fb88 is offline
Mein Auto: 2006 330xi
OP - did you keep the tire psi up to snuff and that right tire is not off too much from the rest?
Old 01-26-2013, 09:48 AM
dgolf dgolf is offline
Mein Auto: X 3
Me too
My 2011 3, also needs the tires replaced, we have done only about 16000 miles. If you come up with a good price let us know as well.
I have tire insurance from BMW[Don't know why I paid for this }, if I buy tires from tirerack, will this be invalidated?
2012 528Xi Black Sapphire Metallic, All Add Ons Except M Sport.
2011 X3 Titanium Silver
Old 01-26-2013, 10:02 AM
My tire/wheel policy from BMW says "OEM" or "OEM-approved". I assume they include the latter because there could be several brands that are approved (e.g. like Pirelli, Goodyear, or whatever tire they decide to use over the years). What I'm not sure about is if I decide to use another brand that never came with the car new (e.g. Michelin, Continental) but keeping with run flats, whether they would qualify as "OEM-approved". I'm hoping yes but will need to check on it.
Old 01-27-2013, 05:06 AM
wavewuver wavewuver is offline
Mein Auto: 2011 X3
I replaced mine at 40,000 miles. They were shot and the left front had significant wear on the outer edge. At the same time, BMW replaced my steering rack. I didn't rotate the tires at all and they were the Pirelli P7's. I bought a replacement set of Pirelli's from Tire Rack and had BMW mount and balance them as soon as they fixed the front end. They also did a 4 wheel alignment. I'm not in love with the longevity of the run flats, but I don't think 40,000 was all that bad.
Old 01-27-2013, 05:33 AM
Mein Auto: X 3
Wave
You are lucky. I rechecked my miles. It is only 19200. THe rear tires are almost running out of thread. The dealer said that it will not pass state inspection, and I will have to replace the tires next month. I will have to find out how much it will cost to mount and balance the tires through BMW and if the dealer will do it?
Old 01-27-2013, 08:58 AM
jdavid2 jdavid2 is offline
Mein Auto: BMW 2011 X3 35i
On my 2011 35i, the P7s are toast after 20K mi especially with excessive wear on the front drivers side outside edge. I don't drive the car very hard but my work commute is primarily city driving. The fronts are a little more (3/32) worn than the rear tires (4/32) and I really noticed the difference driving in the rain yesterday. I never had them rotated but will on the next set. The dealer did several alignments (free of charge) during the first 10K mi while they were diagnosing a right side pull that I had so I'm a little concerned about the outer edge wear on the front drivers side tire. They said they would do another alignment for me after I get new tires. I want to buy from an indepent tire dealer and I"m not sure they will do the free alignment if I don't buy from the dealer. I'd like them to do the alignment so they can do take responsibility if I continue to have any issues with tire wear or pulling.
I will also check on ductman's suggestion regarding Toe "Alignment needs to be set on the toe side at the minimum specs"
Old 01-27-2013, 09:03 AM
I'd be extremely happy if I got 40K mi on any OEM tire.
Old 01-27-2013, 09:19 AM
Mein Auto: 2011 X3
I was happy with 40K considering they were run flats. I am going to rotate my new tires even though BMW doesn't speak to the issue at all.
On a side note, I always thought that the guys with M3's went through rear tires for the obvious reasons. Then I owned an M3 and discovered that even my rear tires wore out quickly, and I didn't light up those rear tires at all. I pushed it real hard though. The rear suspension must be set up in a way that really maximizes rear tire traction, but at the expense of tire wear. So when I hear of BMW drivers saying their rear tires are shot, I understand why.
Old 01-27-2013, 09:48 AM
My '09 MB C300 had same problem with rear tire wear (it was 4Matic). Shot after 22K mi but fronts had some life left. I never lit them up (couldn't even if I wanted to).
Old 01-28-2013, 11:40 AM
Back in the day, I had a Porsche 911 on which, if one did not rotate the tires, the rears were shot in 6K miles. Of course, I was much younger...
Old 01-28-2013, 11:51 AM
smk146 smk146 is offline
Mein Auto: 2011 X3
I am shocked by some of these posts as
My 2011 has 21,000 miles on its OEM tires in New York with terrible roads and at least 50% of the tread remaining. I never rotated them but I am a sticklet about air pressure. I am really surprised. Now having said that I am also the guy who complained that the tires made a noise at times. I thoroughly checked them...no cupping, even wear.
S
Old 01-28-2013, 01:16 PM
S
In the current cold weather, do you know what your pressures are? I have not changed mine since I picked up the vehicle a little over a week ago but I checked them and they are 30F/35R. The plate inside says 32F/38R for under 100mph and I figured I would leave them as is, since the cold weather drops the pressure a bit.
Old 01-28-2013, 01:20 PM
Mein Auto: 2011 X3
I keep them on the high side
Just before the cold snap I had them at 35 in front and 39 in back. When it dropped to about 14 degrees they were closer to 32.5 and 37.
It rides slightly harder but it isnt noticeable to a normal person.
Old 01-28-2013, 01:42 PM
Thanks, I might bump mine a couple of psi since you seem to have decent results.
Old 01-31-2013, 07:19 AM
BuiltnBoostedZ BuiltnBoostedZ is offline
Mein Auto: X3 xDrive35i & 350Z TT
32k miles on my runflats (goodyear ls2). Front tires still have another 10k miles in them. Rears still had tread, but I had a patch in one, so I replaced two tires in the back.
Discount tire accidentally threw away one of the tires I wanted to keep so they had to buy me a brand new one. If anyone wants (1) 245/50/18 goodyear ls2 runflat, let me know. Stickers still on the tire.
350Z TT - SOLD!
2011 X3 xDrive35i
2004 745Li
Old 01-31-2013, 07:38 AM
I might have considered but I have 19".
Old 02-02-2013, 08:34 PM
donkeyjote donkeyjote is offline
Similar story here. At 10,000, SA told me that poor tread life was due to tire inflation but that BMW did not intend for them to be rotated. A mo th later, he changed his tune and suggested I rotate them which I did. Now at 19k and the tires seem to be wearing better but I have been checking the pressure every couple of weeks. No state inspection in AR so I hope to get another 6-12 months.
2011 X3 35i, black sapphire, chestnut, fineline wave trim, premium, technology, convenience, heated seats and steering, roof rails, BMW apps
