Old 01-24-2013, 09:53 AM
toddbmw525i toddbmw525i is offline
Mein Auto: 2003 525i
03 525i.. key will not lock doors..
Key fob won't lock doorsand It's wierdbecause when I physically put the key into the key hole on the driver's door and try to lock the door manually, it won't... And when I try to unlock or lock the door by pushing the lock button on the center console, it won't...
Key fob problems or car electronics problems???
Old 01-24-2013, 10:30 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Console button doesn't work if a door is open or ajar.
Manual lock/unlock requires you to turn the key all the way 90 degrees.
Possible bad cell in key. Try the other master key.
Can you start the engine with the key?
Old 01-24-2013, 11:55 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
FS E39 Hella Celis Euro taillights WITH ballasts, for pre-facelift update.
FS OEM E53 X5 Tow Hitch http://www.bimmerfest.com/forums/sho...49#post9981849
Old 01-24-2013, 12:21 PM
Fudman's Avatar
Fudman Fudman is offline
If you cannot lock or unlock the door either remotely or manually with the key or the inside switch, it sounds like a door lock actuator failure. When the actuator fails, it becomes physically impossible to unlock the door either remotely or manually with the key. If the door is locked, you must then damage the inside door panel in order to unlock the door to replace the actuator. If the door is unlocked, fix it now, immediately! If it locks, you are up the creek without a paddle. Search for my DIY on actuator replacement.
Old 01-24-2013, 07:53 PM
OK, update... I can lock and unlock the drivers door with the key.. But none of the other doors will lock or unlock.
Key will start the car..
