The X5 SAV Forum
Old 12-06-2010, 03:43 PM
oldschool85 oldschool85 is offline
Mein Auto: 2001 BMW X5
No Heat-Blows Cold Air Thru Side and Center Vents
2001 BMW X5 4.4L. Blower fan works, heat works only in defrost and floor mode. No heat coming out of center or side vents.(blows cold air) Dial is set to red mark....
Any Ideas?
Old 12-07-2010, 11:27 AM
Wayne's World Wayne's World is offline
Monkey Wrencher
Mein Auto: 2005 325i Sport 5spd
Well I haven't experienced this problem but I know how the heating system works. Fan blowing (i'm assuming at low, medium & high speeds) and cold air coming out means your heater core is not getting the coolant through it. So likely the heater/blower relay is toast. That's my educated guess. Other possibilities is the heater core is cracked or leaking. But likely you would've either smelled coolant burning or experienced a leak in your cabin.
Old 12-07-2010, 06:39 PM
No Heat
I think if it was the heater core - I would have no heat from the floor or defrost mode... which is working...
Old 12-09-2010, 11:50 AM
Monkey Wrencher
Final stage resistor? Have you come across this in your readings?
2002 Sterling Gray M5
'nuff said
Old 12-31-2010, 04:34 PM
vdv1 vdv1 is offline
Mein Auto: 2005 X5
Your thermostat could be stuck closed which would not allow hot coolant to circulate through the heater core.
Old 01-23-2013, 11:53 AM
malonzo malonzo is offline
Mein Auto: 2005 X5 4.4
malonzo
i have 2003 X5 4.4, same problem heat from floor vent and defroster vent but no heat from center vents just cold air.
Old 01-23-2013, 08:13 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
Have you guys read the owner manual?
Old 01-24-2013, 02:52 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
We have to ask since you didn't tell us that it was ruled out as the culprit like the OP did in the 1st post in this thread "dial is set to red".
What position do you have the stratified air dial? This is the dial (#3) in the middle of the dash's center vent that allows the front passengers to "temper" the air from those vents warmer or cooler...independent of the set temp that is coming from the floor or defrost vents.
Q {BMW CCA Member #191509}
(SOLD)
Old 01-25-2013, 10:18 AM
That's what happened to me when I first try using the heat in the X. Finally read the owner manual and found out about the thumbwheel in the center of the vent.
