wheel sizing - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 01-24-2013, 10:59 AM
mikedonny mikedonny is offline
Mein Auto: 1989 BMW 325i Convertible
wheel sizing
Hello, i drive a 1989 bmw 325i convertible. The PO converted it to AWD, so i don't really know nay of the specs. I was wondering if these wheels will fit.
Rim Width: 8.0 & 9.0
Number of Bolts: 4
Rim Diameter: 16
Offset: 20 & 15
Hub Bore: 57.1
Bolt Pattern:4x100
Old 01-24-2013, 11:46 AM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
you are gonna need to be alot more specific when you say "converted it to awd"
there is no awd system that bolts on, so how did he modify it to make it awd ?
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 01-26-2013, 09:18 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
Do tell. a AWD vert is very unusual if its even possible. Not sure it would be worth the work either. So, either its a 325ix with the roof cut off or its a vert with a 325ix chassis.
E30's have 4X100 bolt patterns unless its a M3. Rim size ranges from 14-15 stock and 15-16 maybe 17's in the aftermarket area. Depending on offset and fender fitment you could run into problems.
Old 01-27-2013, 09:51 AM
It's a convertible with an ix chassis. The PO was a master mechanic and couldn't get his vert up his driveway in the winter so he decided to make it all wheel drive. It's something you don't see every day which is why I liked it.
Old 01-27-2013, 09:11 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
IIRC if its running iX gear, the offset needs to be a lot higher more around the et+40 mark
Otherwise your specs are fine but those wheels are no good to you
someone that has owned an iX will chime in sooner or later
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
