Old 01-24-2013, 02:04 PM
wkt20 wkt20 is offline
Mein Auto: X5
Repairing scratches on dark Burl walnut wood trim
Hi,
I have some scratches on the dark Burl walnut wood trim. What is the best way to Polish / buff out the scratches without damaging the wood trims?
Thanks in advance.
Sent from my SAMSUNG-SGH-I777 using Bimmer App
Old 01-24-2013, 02:30 PM
AutoUnion's Avatar
AutoUnion AutoUnion is offline
Mein Auto: Deutsch Automobil
In for this. I got scratches under the key slot.
I've tried some cheap "scratch remover" liquid from Wallyworld. Didn't do anything.
Old 01-24-2013, 03:00 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
No guarantees, but I've had good luck with a three step process:
(1) Start with Meguiar's Mirror Glaze Cleaner
(2) Then use Meguiar's Plastic Polish
(3) Finish with Plexus Plexiglass Cleaner
This is the plastic equivalent of using Rubbing Compound, Polishing Compound, and Wax on a clear-coat paint scratch.
As with the use of rubbing compounds on clear coats, do not be too aggressive.
Old 01-24-2013, 04:38 PM
ard ard is offline
Resident Curmudgeon
Spot on.
A
Old 01-24-2013, 11:31 PM
Mein Auto: X5
Thanks, I'll give it a go and report back my results.
Old 04-30-2013, 12:14 PM
smyles smyles is offline
Mein Auto: X5
Any results? I have some scratches on the drivers door trim, probably from the watch bracelet.
Oh, and obligatory
Old 07-04-2013, 07:49 AM
thebutlerdidit thebutlerdidit is offline
Mein Auto: 2013 528xi; 2007 X5
My wife has a hairline fracture in the wood trim in her X5. Would this work on that, or do I need to start looking for a replacement piece?
Old 07-04-2013, 09:31 AM
ard ard is offline
Resident Curmudgeon
"fracture"?
No, this will not work.
Basoically this works by removing material next to the scratch until the scratch is gone. If you have a crack you would grind all the way through..... so a super deel scratch of a crack will require replacement.
