Old 01-24-2013, 02:21 PM
Tinoxx Tinoxx is offline
Mein Auto: E64 650I CAB
The Oil Pan Gasket and the Vacuum pump
Hi All
After reading everyone nightmares about seals and gaskets, my car has developed A transmission oil pan leak and a vacuum pump leak.
Does anyone know where do get an Oil Pan & Gasket at reasonable price?
Does anyone know where to get Vacuum pump seals for a good price?
What do you think a good labour price to repair these parts?
Thanks for all responses
/Users/vc_autos/Desktop/IMG_1603.JPG
Old 01-24-2013, 04:55 PM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
If you were here in the U.S., I could help you find an Indy. Look up parts online through a retailer as they should be cheaper than the dealer. Maybe Bimmerzone has the parts that you need.
Once a 6'er, always a 6'er.
Old 01-24-2013, 05:28 PM
HerbP HerbP is offline
There is a DIY in that section with all of the info you need. The pan, filter, & gasket come together as one part. The part number is in the link below. I would suggest that you change the Mechatronics' sleeve also, while the fluid & pan are off.
Good Luck
http://www.getbmwparts.com/parts/200...20TRANSMISSION
