E90/E91/E92/E93 (2006 - 2013)
Old 01-14-2013, 07:35 PM
philage philage is offline
Mein Auto: BMW 328i
Need Tire Recommendations
I have a 2011 328i and it came with continental run flat tires 225/45 R 17 91 H M+S. I'm not pleased with the handling of these tires on the freeway. The car follows any slight groove on the freeway and pulls from side to side. I'm thinking about going to regular tires (without a spare) but want them to handle and track well at freeway speeds as well as around town. Anyone experience anything similar? Any ideas about tire recommendations?
Thanks,
Phil
Old 01-14-2013, 10:54 PM
1zamboni 1zamboni is offline
Mein Auto: 2009 E82 & 2012 E93
Michelin pilot sport PS2 or the new Super sport, I had the PS2 for over 25K miles in two years and still have plenty of treads left.
13 E93 M3 Melbourne Red
12 E93 Space Gray (Retired BMW buy back)
09 E82 Space Gray/Black int/Steps/Sport/Nav/Premium/Xenon/Phone Int/Hifi/269 wheel
2006 E90 ( Sold )
2001 E46 ( Sold )
My next vehicle would be a Zamboni
Old 01-15-2013, 06:25 AM
BMWTurboDzl BMWTurboDzl is offline
Mein Auto: 335D
Bridgestone Potenza 960 AS.
Sent from my MB525 using Bimmer App
Old 01-15-2013, 06:30 AM
jaytank jaytank is offline
Mein Auto: 328i Convertible
I got these (all-season) much better then OEM..
Old 01-15-2013, 06:47 AM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d
Go-flat tires will not solve the tramlining, which is simply the tradeoff of having high-performance low profile tires. It's possible that low inflation is a cause. It's possible that you have an alignment problem. It's possible that Continental's run flats are not as developed as Bridgestone and Michelin.
Old 01-15-2013, 10:27 AM
Rainman519 Rainman519 is offline
Bavarian Garage
Mein Auto: 328i Coupe
Almost everyone in this forum has had a similar issue. Swap the tires for non-RFTs, softer ride, agressive handling, and no trammlining. Problem solved. And oh yea, Michelin Pilot Sports are the way to go. Swapped mine out this summer and couldn't belive the difference. Good luck.
2010 328i Coupe w/Sport and Premium Pkg, Space Gray Met
2003 Z4 Roadster w/sport and premium Pkg, Sterling Gray
2010 Mercedes ML350
2012 Dodge Ram 1500
Old 01-15-2013, 07:20 PM
Mein Auto: BMW 328i
Thanks all! Much appreciated!
Old 01-18-2013, 03:34 PM
JeffreyW85 JeffreyW85 is offline
Mein Auto: 2008 328i
+1 on the Bridgestones. Swapped out the Continentals for a set of these and am much happier. Rides almost like non-run flat tires and the handling doesn't seem compromised. Far less expensive too.
Old 01-18-2013, 03:57 PM
Princeton Princeton is offline
Princeton
Mein Auto: 2008 335cxi
Went with 235-45/17 Continental DWS go flats. Very pleased.
2008 335cxi:GRAPHITE METALLIC:JADE GRAY:GRAY POPLAR:PREMIUM:SPORT:HEATED SEATS:NAV:IPOD/USB
Old 01-18-2013, 04:33 PM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW E90 2007
RE970AS for non-RFT. I love them.
2007 E90 AW 323i Step | Lowered 1.25"/1" | BMW Performance Exhaust | PBX | Debadged | Scangauge II | Style 162 18" & 161 17" wheels & rear 15mm spacers
Old 01-27-2013, 01:14 PM
partspimp partspimp is offline
Mein Auto: 2011 328I
Is the RFT's similar to the PAX tire systems on honda odysseys?? They have a ring on the wheel, which allows the tire to run on in the event of low pressure. Just curious as to how the BMW rft's work.
Old 01-27-2013, 01:34 PM
asus389 asus389 is offline
Mein Auto: 2006 325i
BMW doesn't use PAX. The tires are supported entirely by the sidewall if you lose air pressure.
Old 01-27-2013, 01:56 PM
Dubzdenver Dubzdenver is offline
Mein Auto: A4 /2011 335i ED11/12/10
If you are looking for an all-season, I really enjoyed my Conti Extreme Contact DWS on my old A4. If you are looking for a summer tire I recently swapped my factory Bridgestone RFT's for BFG G-Force Sport-Comp 2's on my '11 335i. So far I love them. I have also run Michelin Pilot Sports on an Audi, so far the BFG's are a better performance tire but with slightly more road noise. I am much happier with go-flats, I also experienced the the side to side and groove tracking at high speeds w/ the RFT's.... not nearly as bad with go-flats.
Hope that helps
November 12 2010 ED
2011 335i Xdrive coupe, alpine white, dakota black leather, msport, nav, cold wx, HK sound, ipod,sat. Redelivered 01/26/2011.
Old 01-27-2013, 05:54 PM
pointandgo's Avatar
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
The PAX system is gone:
http://www.sfmslaw.com/class-action-...ses.php?id=343
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 01-27-2013, 07:51 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: BMW X3
Kumho ku31 great value for money
06 130i
07 320i
08 E92 325i
Bicycles: Giant TCR Advanced Zero, Argon 18 Krypton, Argon 18E114
NEXT CAR : Golf Gti R
Old 01-28-2013, 09:24 AM
If I decide to replace the rft's, what are you guys doing as a back-up? IE...fix a flat, or bmw roadside assist? Ive looked at replacing with the BRS re760 sport tire. The store also quoted new tpms sensors!! Is this normal or covering thier behinds...if a tpms sensor is broken?
Thanks guys!!
