Old 01-24-2013, 03:27 PM
kodishj kodishj is offline
Mein Auto: 2006 530i
Easiest way to get quality bluetooth audio?
I have been looking into various solutions for playing music from my iPhone. I am not sure exactly what I want, but I know that I don't want to spend a ridiculous amount of money on it. I also want to maximize sound quality (no FM transmitters). I know that I will probably have to choose between the two. What are my options?
Here's some information; I'm not sure what's applicable. It's an '06 530i. I have the business professional radio, with hifi speakers. I have the in-dash cd changer, capable of reading mp3s, as well as the 5-disc changer in the glovebox. I don't have an aux input installed.
Is there any product that I can use to replace the glovebox cd changer, where I can use A2DP/bluetooth to stream audio (like a Jambox or Bose Soundlink)? I have bluetooth, but it only works for phone calls. Since I already have the CD changer in the glovebox, do I still need a professional to set up the fiber-optic connection?
Sorry for the overload of questions. Thanks.
Old 01-25-2013, 04:25 AM
Rbsmm Rbsmm is offline
Mein Auto: 2006 550i
I'm looking for the same for my 06 550. I asked my local BMW dealer repair shop and was told the only option I could go with (as far as BMW is concerned) was an audio AUX in place of the CD changer. In other words, the CD changer is replaced by the headphone size audio plug, and not the USB plug which is what I need in order to use an aftermarket BT option.
I'm sure there is an aftermarket USB option out there, but I haven't found it yet either.
Old 01-25-2013, 07:49 AM
Phoenix1 Phoenix1 is offline
Sleeper Wagon
Mein Auto: 2008 E61
If you have access to the earphone type jack that hooks into the AUX port, you connect to Griffin Blue Trip and then wirelessly stream from iPhone and Smartphones. $59 at Amazon. If you don't have AUX option on audio, not sure ...
2014 Audi A7 Prestige E61 SOLD 10/4/13! [/B]- 2008 E61/Monaco Blue/Natural Brown/Premium/Sport/Logic 7/Sirius. Escort 9500ci, Dinan S2 Tune (378HP, 417 ft/lb Torque), RD Sport Sway Bars. Conti DW and Michelin Xi3 snows. LED Angel Eyes, Matt Black Grill. Ext warranty until 2017!!!, 67K miles. Original owner. Fanatically Maintained, BMWCCA Member. Jersey
Old 01-25-2013, 08:06 AM
Phoenix1,
Thanks, that works for me. It would be nice to have the USB instead, so I could control my iphone from the Idrive, but your suggestion looks like the next best thing!
Old 02-15-2013, 06:44 AM
Indy08Bimmer Indy08Bimmer is offline
Mein Auto: 2008 535xi
I have an '08 E60 with the Aux port in the rear of the arm rest(convenient for nothing) but purchased an Aluratek USB receiver that mates with my IPhone. It is a little larger than a postage stamp and about 1/8" in thickness. I placed a velcro strip on it to hold it in place...my only complaints are that it doesn't automatically resync with the IPhone and charging is via a micro-USB charge only. My work around for charging has been to plug in my cell phone charger with a USB slot right next to it. Good news is that the Aluratek was about $30 at Best Buy and the sound is great. Works much better than the direct connect to the headphone jack.
Old 07-13-2013, 08:54 PM
giarC71 giarC71 is offline
Mein Auto: 2012 528xi
Thanks for the recommendation Indy. Works Great. ON my 09 E60
Old 07-15-2013, 07:40 AM
Mein Auto: '06 AW 330xi
You can install an aux input into your HU for cheap. The harness is like $40-50 but you have to code the HU to activate it. I can take care of the coding for you if you're in the Philly or NJ area.
I used to use a blackberry stereo gateway with my aux port. My iPhone paired to both my car's bluetooth, as well as the stereo gateway. Calls would fade music out and back on when you took and hung up a call, respectively.
Old 06-03-2014, 09:35 PM
850csi 850csi is offline
Mein Auto: E90/E61; N52B30^2
Fellas, I assume there's no sort of aux adapter cable that just plugs into the CD changer cable itself?
Old 06-04-2014, 06:05 PM
baro1220 baro1220 is offline
Mein Auto: car
Do you have iPod cable in the glow box?
Old 06-05-2014, 08:54 AM
txag_530i's Avatar
txag_530i txag_530i is offline
That's correct. You have to buy a device that converts the analog signal into a fiber optic signal if you want to use the CD changer cable. The Gateway is one product line.
a2dp, audio, bluetooth, e60 5-series, mp3
