E34 (1989 - 1995)
540i misfire and start prob
bmw 540i e34 takes forever to start and when started there is a misfire
fixed a cracked manifold.replaced fuel pump but still no results if someone knows what the problem is help |
Check the crankshaft position sensor. Should be 540 +/- 10% ohms. Check main relay. Check fuel pump fuse and fuel pump relay. Check fuel pump.
Get the Bentley manual and read, read, read. Good luck.
Steve Calypso Red 1992 525i with 170K miles 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
i would check spark before fuel. seems like a bad coil or plug even...
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros |
I would be inclined to check plugs and coils. I suspect coils can be tested and the Bentley manual, already reccomended, should have the specs.
When you replaced the fuel pump did you verify fuel pressure? Can you hear the pump run? If no pressure follow the relay advice from BMRLVR. Check for other vacuum leaks, cracked hoses, fittings.
Winter Rules
thats the thing.8 bosch spark plugs was put in.as for coils there was one dead so i replaced.fuse,relay that was the first thing i checked.as for the sensor where to get new one remember south africa
Buy a parts car.
I would go with others and check for spark. If it's not spark plugs or coils and you replaced fuel pump, I would check for fuel pressure. Lastly, check for compression between 142-159 psi. Are you throwing a code? I'm still new to OBDI but it might point you in the right direction at least.
2008 Infiniti G37, 1994 BMW 530i, 2011 BMW 328iT |
