E46 (1999 - 2006)
Old 01-25-2013, 02:46 PM
VP VP is offline
Mein Auto: 2003 325i
Originally Posted by smolck View Post
Buy some matches and light your car on fire.
Or as we used to say: "Clean with Gasoline -- Dry with match"
Light a man a fire and he'll stay warm for a day. Set a man on fire and he'll be warm the rest of his life.
Old 01-25-2013, 08:48 PM
mexakin05 mexakin05 is offline
Mein Auto: 325Ci
Don't torture the BMW! You should bought yourself a Neon! LoL!
Old 01-25-2013, 10:35 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by kshade40 View Post
Looking to spice things up a little any ideas!?
To start it off, here are some lists of lists that I'm aware of for parts:
  1. O-rings to stock up on (1)
  2. Wiper blade inserts to stock up on (1)
  3. Bulbs to stock up on (1)
  4. Vacuum hoses to stock up on (1)
  5. Gaskets to stock up on (1)
  6. Cooling system parts that you will always need (1)
  7. Fuses to stock up on (1) (2)
  8. Belt-drive system parts to stock up on (1)
  9. Alternator rebuilding bearings & diodes to stock up on (1) (2) (3) (4) (5) (6) (7)
  10. Brake pads (1) & rotors (1)
  11. FSU/FSR (1)
  12. Parts suppliers (1)
Here is a starter list of lists for fluids to stock:
  1. Glovebox printout: BMW E39 fluid summary printout for your glovebox (1)
  2. Motor oil: BMW approved motor oils (pdf) & tribal motor oil recommendations (1) (2) (3) & gravity oil change DIY (1) (2) (3) (4) (5) & vacuum extraction DIY (1) (2) (3) & drill pump DIY (1)
  3. Gasoline: Engine fuel & octane (1) & "The Gasoline FAQ" & top-tier gas stations (1) & Techron additives (1) & how to clean your gas gauge sending unit (1) & mpg calculations (1) how large is the fuel tank and reserve in the E39 (1) & what gasoline to use (1) & how much gas should be left to cool the fuel pump (1) & how to siphon the fuel out of the tank (1) & what is the cost differential between 87 & 91 octane AKI (1)
  4. MTF: Manual transmission fluid (1) (2) & manual transmission fluid-change DIYs (1) (2) (3)
  5. ATF: Automatic transmission fluid (1) (2) (3) (4) & automatic transmission fluid & filter DIYs (1) (2) (3) (4) (5) & torque values (1) & how to find the hidden E39 transmission fluid level dipstick (1) & why ATF gushes out of the fill hole (1) & ZF 5HP19 facts (1)
  6. PSF: Power steering fluid (1) (2) & power steering fluid flush DIYs (1) (2) (3) (4) & volumes (1)
  7. Coolant: Coolant, for engine, automatic transmission, power steering, and AC evaporator cooling (1) & bleeding (1) (2) (3) or refilling DIYs (1)
  8. Brake & clutch fluid: Brake & clutch hydraulic fluid (1) & recommended E39 brake job "fluids" (1) & how brake bleeding DIYs (1) (2) (3) (4) (5)
  9. A/C: Air conditioner refrigerant & PAG oil (1) & how to refill your A/C system (1) (2) (3) (4) & what to use to rid yourself of the BMW gym sock stink (1)
  10. Differential: Rear differential hypoid gear oil (1) & differential fluid change DIYs (1) (2) (3)
  11. Battery: What battery (1) & what battery maintenance (1) & battery electrolyte (1) & battery replacement DIY (1) (2) (3) & how NOT to change the battery (1) (2) (3)
  12. Windshield fluid: Windshield washer fluid (1)
  13. Intensive cleaner: Intensive cleaning system fluid (1)
  14. Windows: Window glass cleaner fluids & cloths for the inside window & windshield glass (1)
  15. Tire air: Recommended tire pressures (1) (2) (3) & the claimed benefits of nitrogen gas (1) (2)
  16. Wheels: Best product for cleaning wheels (1)
  17. Interior: Interior cockpit & dashboard cleaners (1)
  18. Carpets: Suggested carpet cleaners (1)
  19. Floormats: Suggested floor mat cleaning & shampooing (1)
  20. Headliner: Solvent for cleaning the headliner fabric (1)
  21. Vapor barriers: Sealant for door panel vapor barriers (1) & sizes for the adhesive (1)
  22. Engine cleaner: External engine degreaser, engine bay cleaning & engine compartment detailing (1) (2) (3) (4) (5) (6) (7) (8)
  23. BMW list of lubricants, sealants, & thread lockers (pdf) (shrunk gif) (original-size jpg)
Likewise, here's a list of lists for tools to keep on hand (that you might not otherwise have):
  1. Basic tools for working on the E39 (1) (2) (3)
  2. Basic scanning tools for the E39, OBD (1), SRS (1)
  3. Precision measuring tools such as dial gauges & calipers (1)
  4. Advanced scanning tools for the E39 (1)
  5. Tools for a cooling system overhaul (1)
  6. Stocking the trunk BMW toolkit (1) (2)
  7. Emergency items in the trunk (1) (2) (3)
Old 01-26-2013, 04:32 PM
delirium330's Avatar
delirium330 delirium330 is offline
John Voight's BMW
Mein Auto: 05' 330i ZHP 6MT
no shout outs for the sock mod?
My Merit Badges:
CVV, VCG, OFHG, Full Cooling System, Tensioners, Plugs, All Fluids, Fuel Filter, Angel Eyes, Kidneys, Badges, Front/Rear Clears, Battery, Brakes, CDV, V1 Install, TB Housing, ICV.
Old 01-26-2013, 05:25 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Good thinking. That is one free mod that is worth doing.
Old 01-26-2013, 05:50 PM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
Not that we condone shoplifting socks...
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 01-26-2013, 08:33 PM
smolck's Avatar
ROLL TIDE!
LOL, that was pretty funny.
Old 01-26-2013, 08:38 PM
TannerT TannerT is offline
Mein Auto: 03 330ci 3pdl 89 325i
we here at the fest are always up to nothing but good
Sent from my PantechP9060 using Bimmer App
[SIGPIC]s[/SIGPIC]Formula SAE "Speed is Sexy"
Old 01-27-2013, 12:34 AM
bluebee's Avatar
For those wondering about the BMW sock mod ...
Originally Posted by bluebee View Post
BMW M-sock mod (see video below):
Old 01-28-2013, 11:12 AM
TacoBuster's Avatar
TacoBuster TacoBuster is offline
Mein Auto: 2003 325Ci Conv
Aha just make sure u dnt squeeze the tip.
Old 01-30-2013, 03:32 PM
valentine323i valentine323i is offline
Mein Auto: 2006 bmw 325i
Rofl i would go with the ebai deal red calipers and interior are spicy though
