E36 (1991 - 1999)
Old 01-24-2013, 05:00 PM
relldave relldave is offline
Mein Auto: 97 328is
Unhappy E36 FPR probles.
Im trying to replace my fuel pressure regulator and can't get it to push all the way back into the hole so that i can instal the u clip. Can anyone help me
Old 01-24-2013, 05:29 PM
jonesin's Avatar
jonesin jonesin is online now
The Canadian Prick.
Mein Auto: '96 328is Cosmos
http://www.pelicanparts.com/BMW/tech...eplacement.htm
Hope this helps.
Ed.
Sent from my U8651T using Bimmer App
“No cop born isn't a sucker for a finely-executed hispeed Controlled Drift all the way around one of those cloverleaf interchanges. Few people understand the psychology of a traffic cop. A normal speeder will panic and pull over to the side when he sees the big red light and start begging for mercy. This is wrong. Contemptuous to the cop-heart. When running along about a hundred and you find a redflashing CHPtracker on your trail you accelerate.”
- Hunter S. Thompson,
Old 01-24-2013, 06:03 PM
Mein Auto: 97 328is
Exclamation
Hope this helps.
Ed.
No. I have the one that's installed under the car next to the fuel filter.
For whatever reason i can't get it to push all the way in. I don't know if maybe it has something to do with the fuel pressure, if so how do ideal with it. Thanks.
Old 01-24-2013, 06:16 PM
drivinfaster's Avatar
bimmerfest Supporting Member
Mein Auto: rescued bmw's
regardless, i think the point of the article that ed linked was that you should use some lube on the o-rings to aid in instaling the new fpr.
the article stated white litium grease, but i have used 90w gear oil as well. just a tiny bit, though. no need to go crazy with the lube.
then even pressure until it seats. you do not want to kink or rip the seals.
double check for leaks when done.
where in nj are ya??
df
Old 01-24-2013, 06:24 PM
jonesin's Avatar
The Canadian Prick.
Thanks for going into more detail on that df. I've had no reason (yet) to touch my fpr.
Old 01-24-2013, 06:27 PM
that's cuz you drive like a hoser....
(you know we all still luvz ya ennyway, rite??)
df
97, bmw, e36, fpr, fuel pressure regulator
