E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008)
Coupe and Roadster talk with our gurus here... |
New top
2004 Z4 2.5....... Top was damaged, had replaced, they did a great job, but there is more cabin noise now. Any suggestions... Doesn't leak, seems tight. It has a head liner. Is it possibly not as insulated. Anyone else had the same problem and is there a way to cut down on road noise
Did they use an OEM top?
Drive with the top down then
![]() Seriously, it takes very little material sticking into the airflow to make a lot of noise. Look at the fit at the top of the windshield and around the side windows. Years ago I had the noise drop after replacing the top on an old Triumph. Looked to me like the only difference was the after-market top material was a whole lot smoother than the factory rag. |
Did you try turning up the radio?
Seriously! Take a look at the fit between the windows when they are rolled up and the new top, if there is a gap there it can result in noise? Good luck
And he's got a Triumph so he knows all about wind noise!
Yeah!!! Noisey, Smelly, Leaky, but I LOVE it!
Thanks again for your responses. |
It is part of the experinece....
I often pine for my long lost TR8, grumpy old beast that it was. Less so for the Fiat that came before it. Good luck with the top. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
