Old 06-15-2011, 12:40 PM
tmoney1h tmoney1h is offline
Mein Auto: Texas
Exclamation 2002 745li radio reception problem
Can any one help? I own a 2002 745li and my radio is trippin (for lack of a better term). It will not lock into a radio station on FM or AM. It happen once before but the problem went away after a day or so. It's been out for months at this point. The dealer is suggestion radical repairs to the iDrive system $$$. Everything else is working fine, CD, Nav, ect.
Old 06-16-2011, 11:57 PM
mikegoblan mikegoblan is offline
A 7 series Fanatic
Mein Auto: BMW 745 Li
So if you put on a station, it changes automatically ? What happens on the I-Drive screen ? does everything changes too or it stays the way you put it ?
If the radio is completely out but every other multimedia feature still works, then you probably have to replace the radio unit. it's located on the rear passenger seat (behind the driver) in the corner where the seatbelt is.
This should give you an idea of what the unit looks like and where it's located
http://66.163.168.225/babelfish/tran...%2fM_Radio.htm
If the radio unit is not the problem, then you probably need to change the ASK CD unit. it's the single CD unit in the dash bored, next to the telephone.
Hope this helps.
"It's all about what's worth living for" Quote by me
2003 BMW 745 Li black on black
Old 06-17-2011, 01:06 AM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
do you have any modifications including white angel eyes?
Old 07-22-2011, 08:54 AM
Mein Auto: Texas
mikeglobal,
Thanks for getting back to me. The radio will not lock into a station, it goes into a continues scan. The I-Drive screen does not change. I'll follow up on your suggestion and start with replacing the radio.
Old 01-23-2015, 12:26 AM
jassoo jassoo is offline
Mein Auto: BMW 745iA
Did you ever got this fixed ? I have a same problem.
