E36 (1991 - 1999)
Old 01-25-2013, 03:09 AM
RaunoV RaunoV is offline
Mein Auto: 318is 2.5i
318is Engine swap results Tachometer failures
Hi!
Recently i changed my 318is (1995) engine for 525i (1992) one. Almost everything seems to work properly. One of the major issues at the moment is that after driving for a while with warm (temp. gauge in middle) engine tachometer and fuel gauge start jumping and die/drop to 0. When turning on additional electrical devices (for example blow to max, fog lights or using power windows) then these gauges wake up and work a bit more or until i turn those additional devices off. Has anyone any idea about this weird problem?
Second issue is that my full OBC show very funny fuel consumption about 4-7L/100km on highroad but when fuel gauge is working it shows about 10L/100km.
I would really appreciate if anyone has opinions or possible solutions..
Regards,
RaunoV
Old 01-25-2013, 08:49 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
You didn't swap in an instrument cluster for a 6 at the same time you replaced your 4 with a 6, did you? The 4 cylinder cluster will work, but it won't read correctly. You need a 6 cylinder cluster. Also, it sounds like your connections on the IC are loose.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 01-25-2013, 08:56 AM
Difference in 4cyl and 6cyl cluster is just how right rpm-s are, and I changed them also. This problem occurred on both clusters. Probably not connections cause both clusters had same issue and this is somethings to do with engine temerature?! Or somethings with electrical system...
Old 01-25-2013, 09:32 AM
D'oh, You kids!
Electrical system. And why do you think it can't be connections since it does it on both clusters? If the connector plugs are bad, that's exactly how it would react, showing the same symptoms on both clusters.
Quotes to live by:
BMW-CCA #441426
Old 01-25-2013, 09:43 AM
And how could you explain that engine swap caused it? As before there wasn't any issues.
Old 01-25-2013, 11:00 AM
B1MM3R's Avatar
B1MM3R B1MM3R is online now
Jesse Moon Bayne
Mein Auto: '93 ///S50 powr'd 318is
Did you make sure all of the ground wires are connected securely?
Jesse
Part out.
http://bimmerfest.com/forums/showthr...67#post7418867
"Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI
Stock 2004 X5 3.0i (Wifes)
E30 87 325e
Old 01-25-2013, 12:01 PM
I think so. Weird is that it always happens after some time of driving, about 20-30km..If ground is bad, sould it affect all the time?
Old 01-25-2013, 12:03 PM
B1MM3R's Avatar
Jesse Moon Bayne
Not all the time. My dads 318 cluster would randomly act nuts and then he found the ground was loose, tightened it and voila it was fixed.
Jesse
Part out.
E30 87 325e
Old 01-25-2013, 12:06 PM
Mhh, okay. Need to find some diagram to check all grounds and not miss any of them.
Any ideas about the second issue? About second issue I noticed that Range is also acting very weird. Today started driving with 98km and after arriving destination (15km) it showed 30km to go..
Old 01-25-2013, 12:33 PM
B1MM3R's Avatar
Jesse Moon Bayne
Are you sure you have a 6 cylinder cluster in the car now? B/c range will be off if not.
Jesse
Part out.
E30 87 325e
Old 01-25-2013, 12:50 PM
Yes, old 318is cluster showed way higher rpm-s. With this cluster rpm-s are normal.
But does that matter that i have 525 ECU? As new engine is older and they don't match with OBC?
Old 01-25-2013, 12:59 PM
B1MM3R's Avatar
Jesse Moon Bayne
No, all of the dme's are the same with (6 cylinders) electrical but just the chip is different in the dme per which engine you have. Im not sure then.
Jesse
Part out.
E30 87 325e
Old 01-25-2013, 01:04 PM
Can it be something related to engine temperature sensors?
AS how this ground always fails after some time of driving?! Really confused..
Old 01-25-2013, 01:09 PM
B1MM3R's Avatar
Jesse Moon Bayne
Not sure, any CEL on?
Jesse
Part out.
E30 87 325e
Old 01-25-2013, 01:14 PM
Not in cluster, OBC's Check function fails and turns OBC off..
Old 01-25-2013, 01:25 PM
B1MM3R's Avatar
Jesse Moon Bayne
I know what they do...I was saying for the first issue where you asked about temp sensors causing rought idle.
Jesse
Part out.
E30 87 325e
