Old 01-25-2013, 05:06 AM
osikani osikani is offline
Mein Auto: 2000 528I
Arrow Heater not working
Folks, for the past month, the heater is not working properly; it's been intermittently. Since Monday there's no heat at all in this severe cold weather in NorthEast. I've read a lot of posting here, some says it's the heater valve, FSU, cooling system flush etc.
This is what I did this morning, I check the heater valve and it's cold. I set the temperature to 60 F and switch to cold and cold air comes alright, then switch to 90 F and still cold air but not as cold as 60 F. Then change to 90 F and switch to heat and no air comes at all. Check the air at the cabin filter under the hood and it's cold. Finally, car temperature is cold just above the blue mark, never got to middle since Monday.
I need help now since I'm freezing in this brutal weather.
Thanks for you help!!!
Old 01-25-2013, 05:37 AM
JKRIT JKRIT is offline
Mein Auto: '03 525i
Your last remark, that the engine temp only gets just above the blue mark, indicates that the thermostat is stuck open. I would start by changing that, keeping in mind the technique needed to bleed all the air out afterwards.
Old 01-25-2013, 07:19 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Could be a bad auxiliary pump. Bottom left side (driver side) of the radiator.
Usually when this one goes out, there's no heat in the cabin.
To check: Open the expansion tank cap, car in "P", key in pos2, HVAC set to your normal heat comfort.
You should hear the coolant gurgling, and also see a stream of coolant (if it's topped off) coming from the upper snaked hose that sits on top of the radiator. If nothing happens, the pump is dead and needs replacing.
Good luck.
Old 01-25-2013, 02:54 PM
houckjf houckjf is offline
Mein Auto: 1999 528i wagon
Heater not working
1999 528I - have the same problem with the added issue that the temp gauge is pegged all the way in the RED Don't know what to do or check.
Old 01-25-2013, 05:48 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
Start with checking the coolant level.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 01-25-2013, 06:09 PM
thanks for the rely but the coolant level is good
Old 01-25-2013, 06:15 PM
Did you check the water pump belt?
Steve
OSRAM CBI
Old 01-25-2013, 06:17 PM
No I haven't will look at hat in the morning
Old 01-26-2013, 05:25 AM
checked water pump belt and it is good
Old 01-26-2013, 05:30 AM
bmwoem1 bmwoem1 is online now
Past Sponsor
Mein Auto: X3
If the engine temp never gets to normal than you have a stuck thermostat.... I have the occasional plugged heater core, but I would change the thermostat first
Old 01-26-2013, 07:44 AM
First, as you know, severe engine damage can result when your engine overheats. So you need to address this issue immediately.
Second, I assume that the temperature gauge is operating normally. That is, it starts at the cold mark and moves toward the hot mark as the engine heats up.
With the symptoms you describe, no cabin heat and the temperature in the red, it appears that the coolant is not circulating through the engine. That could be because the thermostat has failed closed. Or maybe the water pump has failed and is not pushing water into the engine.
Either way, it appears that you need a cooling system overhaul. You should probably check the cylinder compression to assure there is no engine damage.
Steve
OSRAM CBI
Old 01-26-2013, 07:54 AM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
replace thermostat first
if temp gauge if left of straight up, you thermostat is stuck open .
Old 01-26-2013, 04:27 PM
Thanks for the tips I really appreciate them will post what I find when its fixed and I'm no longer freezing my .......off driving to work lol
Old 01-27-2013, 02:08 PM
the1t the1t is offline
Mein Auto: e39 525d
try changing the fsu, i had a similar problem and that fixed it.. the part is cheap and you can change it yourself in 10-15 mins.. you can pick one up with warranty from ebay
Old 01-27-2013, 02:21 PM
FSU? what is it and where is it located?
Old 01-27-2013, 02:37 PM
Mein Auto: e39 525d
Final stage unit.. Its in the footwell on the right hand side.. If you type it in on you tube theres 10 videos on how to do it.. Guaranteed scratches on ur hands
Old 01-27-2013, 04:28 PM
Mein Auto: '03 525i
Changing the FSU brought your temp gauge down out of the red?
Old 01-27-2013, 04:32 PM
Mein Auto: e39 525d
No but it fixed the problem with the hot and cold air.. Worth a shot for what it costs i reckon
Old 01-27-2013, 05:18 PM
Mein Auto: '03 525i
houckjf may indeed have a dead FSU disabling cabin heat, but overheating a BMW I6 is a much more serious problem, as pointed out by Steve530. Houckjf should not be "driving off to work" that way.
Old 01-27-2013, 05:37 PM
I changed the thermostat and heat is now back. Thanks guys, u r the best.
Old 02-16-2013, 12:49 PM
Thumbs up
thanks all for the advice, replaced thermostat and water pump now I got HEAT LMAO>>>>>
Old 02-16-2013, 02:37 PM
Glad you got it fixed.
Steve
OSRAM CBI
Old 02-16-2013, 02:50 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
Originally Posted by jkrit View Post
your last remark, that the engine temp only gets just above the blue mark, indicates that the thermostat is stuck open. I would start by changing that, keeping in mind the technique needed to bleed all the air out afterwards.
+1
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
